-   -   MTD yard machine lawn mower (http://www.diychatroom.com/f16/mtd-yard-machine-lawn-mower-104140/)
qrilty 05-11-2011 08:55 AM
I can't get it to start. The carborator isn't getting fuel. I replaced the fuel line and filter and the solenoid on the bottom of the carb. It will start if a put a few drops of fuel into the carb.
sixeightten 05-11-2011 09:17 AM
Make sure the choke is not stuck. Sometimes debris can get in there and the linkage will get stuck.
DrHicks 05-11-2011 09:53 AM
So you're not getting gas TO the carb, or not getting gas THROUGH the carb?
If you're not getting gas TO the carb, it should be pretty easy to diagnose & fix.
If you ARE getting gas to the carb, there's a good chance you've got dirt in the bottom of the bowl, and it is plugging your jet. The fix for that is also relatively simple.
bernieb 05-11-2011 05:52 PM
That solenoid that is in the bottom of the carb bowl, can you see the plunger going back and forth while cranking with the bowl down? I think this solenoid is a fuel pump, but not sure. I had a similar problem and replacing the "pump" cured it.
