Mower Won't Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 06:13 PM   #1
Mower won't start
Toro 22" recycler. Had to replace the starter/pulley assembly because it broke at the end of the season last year. Replaced the pulley assembly, won't start. Had old gas, but with a stabilizer. Dumped old gas, put in fresh gas, won't start. Replaced spark plug, won't start. Cleaned the carburetor with cleaner and compressed air, won't start. Also replaced air filter and gave it an oil change. Fuel lines look to be clear. Anyone have any ideas what else to try before I have to have to pay someone to fix it??
dmlove67 is offline   Reply With Quote
Old 03-15-2013, 06:27 PM   #2
Rewards Points: 22
Does it sound like it's trying to start? Did you have to remove the flywheel when you replaced the starter?
djlandkpl is online now   Reply With Quote
Old 03-15-2013, 06:39 PM   #3
Didn't have to remove the flywheel. Doesn't really sound like its trying to turn over either.
Old 03-15-2013, 07:15 PM   #4
Rewards Points: 22
2 things you can try. Pull the plug and try to start it a few times. See if you smell gas from the plug hole. Also check the plug for spark.
The Following User Says Thank You to djlandkpl For This Useful Post:
Dave Sal (03-16-2013)
Old 03-15-2013, 07:46 PM   #5
That was the next thing I was going to check in the morning. I'll let you know what happens
Old 03-16-2013, 10:24 AM   #6
After some googling. I took off the air filter and shot a quick burst of carb cleaner into the carb. It started right up. I let it run for a long time and kept turning it off and starting it back up, no problems. I think something must have been clogged somewhere and the cleaner unclogged it. Works like new! Thanks for the input.
Old 03-20-2013, 05:15 AM   #7
Rewards Points: 127
I always run my snowblower and mower dry at the end of the seasons... Never had a problem.. always had problems when using stabil
sh40674 is offline   Reply With Quote
Tags
lawnmower , mower , mower repair
HELP!!! Dixon 4423, 2001 ZTR mower geoffb Landscaping & Lawn Care 4 08-13-2012 01:01 PM
Trying to replace electric mower switch with normal light switch orrgroup Electrical 6 06-12-2012 05:45 PM
Furnace won't start MDA HVAC 2 11-30-2011 10:59 PM
Lawn mower starts then dies gazz87 Landscaping & Lawn Care 8 11-19-2011 01:43 PM
Briggs Stratton wont start - 12hp model: 498027 inetquestion Landscaping & Lawn Care 2 04-16-2010 06:57 PM
