Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-08-2011, 06:20 PM   #1
mower will not start
have replaced starter switch, battery, solenoid. wired correctly from on-line diagram. still will not start. any ideas?
joey70 is offline   Reply With Quote
Old 05-08-2011, 06:23 PM   #2
sdsester's Avatar
Spark plug is shot or improperly gapped? Clean gas, not last year's? In tank or in gas can? Try pulling the plug and putting just a shot of WD 40 down the shaft to give a possible frozen valve a shot. Clean, replace, gap the plug and see if that helps. Filter over carb has been cleaned and oiled for the season? Carb look all gummed up when you had it off?
sdsester is offline   Reply With Quote
Old 05-08-2011, 09:25 PM   #3
But can you get spark at the plug?, like able to jump an air gap of at least a quarter of a inch or more? like the other poster said last years gas is no good. You can also use a product called "sea foam" to add to new gas,it breaks down the built up carbon inside cylinder area,along with rings that carbon up,it improves compression and you will get a lot of smoke during the decarbonizing process.
bernieb is offline   Reply With Quote
Old 05-08-2011, 10:04 PM   #4
Ether bomb. (aka starter fluid). Old gas sat in mower all winter. Old gas in gas can, too. Can of ether bomb (aka starter fluid ($2.00?)) got it started in one pull.
mwpiper is offline   Reply With Quote
Old 05-08-2011, 10:34 PM   #5
BIGRED
If the engine spins with the starter, and has a one or two lung aircooled magneto fired engine unplug the magneto "P" lead that kills the engine when it is grounded. Now try to start it with the choke full on. It may only pop once or twice, but you can go to half throttle so it is not being choked and try it there after you get the first pop or so. All the stuff you have changed only runs the starter motor so it can spin the engine. Depending on how old the engine is the magneto could be bad or dead also.
Grampa Bud is offline   Reply With Quote
Old 05-09-2011, 08:58 PM   #6
good idea to remove the float bowl under carb , clean it out and make sure the feed jet isnt gummed up . usually the bolt holding the bowl is the jet to . blow through it to clean it . even if you drain the gas tank there is almost always gas and dirt left in the bowl .
oldrivers is offline   Reply With Quote
Air Compressor blowing start capacitors? BBC3 Electrical 9 04-28-2013 12:34 PM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 11:52 AM
TORO Mower vabear Landscaping & Lawn Care 2 06-04-2010 01:31 PM
Briggs & Stratton Fuel Problem/ No start rod46 Landscaping & Lawn Care 4 05-09-2010 03:53 AM
Briggs Stratton wont start - 12hp model: 498027 inetquestion Landscaping & Lawn Care 2 04-16-2010 07:57 PM
