Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-18-2011, 12:42 AM   #1
Moving / Lifting big rocks by hand?
I had some grading work done in my backyard which brought up a lot of fieldstones. A friend is building a rock wall in the next town and asked me to put these rocks to the side for him (he hauled an entire farmer's wall off my property last year at no charge, so I'm happy to help him out).
Many of these rocks are liftable by one person, and I can roll them all with a rock bar, but there are a couple that really need 2-3 sets of hands to lift them into the truck, using ramps. The problem is actually just getting a grip on these rocks. Is there any sort of commercial sling or net that we could roll these rocks into and use for handholds? I'm thinking something like a cargo net or wire cable harness.
And, yes, the grading was done by machines that could have easily put these rocks in my friend's truck. The landscapers didn't want to get involved dropping rocks into a pick-up truck.
Thunder Chicken is offline   Reply With Quote
Old 08-18-2011, 06:56 AM   #2
DIY Hack
Mr Chips's Avatar
I would just get some chain and quick links and make a Tsumaura Sling like they use to lift boulders by helicopter
Take a piece and make a loop around the bottom. Then cross 2 pieces and connect to the bottom loop on each end
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Thunder Chicken (08-24-2011)
Old 08-19-2011, 01:26 AM   #3
Yes, you may move those heavy rocks using your bare hands but there are some tools that can be used to help you do the job easier. For moving heavy objects such as rocks, you'll be needing Winch or a Pry Bar. Pry Bar is tool that can be used to help you get heavy rocks out of the ground so that they may be rolled, wedged or moved to a new location. Whilst Winch is a tool for leveraging that will let you move heavy objects such as rock.
sassyconnie is offline   Reply With Quote
Old 08-24-2011, 05:50 PM   #4
With a chain sling, you might be able rent an engine crane(put on plywood or something stable) and remove the tailgate.
Back the truck right to the rock and location.
Stillwerkin is offline   Reply With Quote
Old 08-24-2011, 05:59 PM   #5
Tileguy
Bud Cline's Avatar
There are also web-strap slings made for two men to use to lift boulders and balled-trees. Nurserymen use them.
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 08-24-2011, 08:15 PM   #6
I have a rock bar and shovels and such, and I can lever the rocks around without too much difficulty. It is just the lift up into the truck that is a problem. A ramp really isn't an option as the ground is really rugged.
Thanks for the pictures of the slings. Are the nursery ball slings available commercially or are they a home-brew sort of thing? Fabric straps would be ideal.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Drainage Rocks? Katigan Landscaping & Lawn Care 3 04-16-2010 08:25 PM
From rocks to grass -Q- Landscaping & Lawn Care 3 04-04-2010 07:03 PM
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 02:04 PM
question about using rocks pesphoto Landscaping & Lawn Care 2 10-27-2007 03:00 PM
