Moles Unde Pool Liner...causing "craters" - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-26-2007, 09:58 PM   #1
Moles unde pool liner...causing "craters"
I have a 2 acre lot with an above gound pool. My problem is moles. They have, on several occasions, tried to come up under the pool. Once they determine that they can't, they apparently turn around and tunnel back down. This causes a recess between the earth and the liner which in turn, due to the weight of the water, develops a "crater-like" depression in the floor of the pool , around the edges. Each year it seems like we get one more. What can I do to keep moles away from the pool area? Thanks for any advice.
abacuslearns is offline   Reply With Quote
Old 10-27-2007, 07:37 AM   #2
so-elitecrete
Rewards Points: 150
that's interesting,,, usually moles're out for food (grubs, etc),,, grub-proof your lawn & the moles leave,,, back home, skunks were predators of moles,,, ANOTHER good reason to grub-proof,,, at least your pool's above-ground IF there was a gravel base w/sand under the pool proper, why moles,,, interesting,,, might try ' no exit ' signs in molish, too
so-elitecrete is offline   Reply With Quote
