Miami Sprinkler System Using Well Water...help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 08:44 PM   #1
Rewards Points: 115
Miami sprinkler system using well water...help
I recently had installed a sprinkler system that gets its water from a well 20 feet down known as the Miami Aquifer. My sprinkler heads are constantly getting clogged with silt and sand, and thus dont spray much (or anything at all). I clean them out, but the silt returns. I mentioned it to the installer, and he offered a service that cleans the lines out with some special device = $100.
The pump has a hose fitting on top which allows me to run water as long as I want, in essence, cleaning things out. I realize that doesnt clear the pvc lines underground, but it cleans the uptake tube that comes up 20 feet.
Any ideas on preventing the silt build up? Was he just looking for a quick $100 and blowing smoke up my a$$? Do I have a way to clean out the lines (removing the heads and letting water flow for a few minutes)?
NABRIL is offline   Reply With Quote
Old 04-24-2012, 08:47 PM   #2
Rewards Points: 14,290
SOunds like your trying to set the pump to close to the bottm of the well.
As you said just removing the heads and letting the pump run should clean it out.
I would do one head at a time that way there more pressure.
NABRIL (04-24-2012)
Well water clorination system questions scrupul0us Plumbing 11 05-17-2015 06:59 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
Desiging a manifold water system? BowDown Plumbing 1 07-20-2009 11:00 AM
