#1 |
Manual aeration
I use this to manually aerate my small lawn every September. I look like a fool, but it helps! My question is is this as effective as hiring a Pro?
#2 | |
Manual aerationQuote:
http://www.amazon.com/Hound-Dog-Prod.../dp/B00023S156 |
#3 | |
What's the best way to do it? Every 1 foot or more? |
#4 | |
You have to do it when the ground is somewhat moist, to make the plugs come out easier. Then, you can overseed if you wish. |
#5 | |
#6 | |
It will also work better if your lawn is not too high. The only thing is that your shoes may get muddy. |
#7 | |
#8 |
Manual aeration |
#9 | |
#10 |
Manual aeration |
#11 | |
#12 | |
#13 |
Manual aeration
I assume you're saying this b/c the cores aren't getting pushed out easily?
If your lawn is small enough, you could always run the sprinkler and then core aerate if you want to get it done during a weekend. Or, you can rent a power core aerator from a place like HD for ~$60 and split with a neighbor. If you have such brown grass, you might want to dethatch, core aerate, and then overseed. |
#14 |
Manual aeration
I also have this green device for my dethatching duties
http://www.cleanairgardening.com/dethatcher.html Last edited by handy man88; 09-17-2011 at 07:59 PM. |
#15 | |
| Display Modes | |
| Choosing a manual transfer swtich for 7500 w generator | homerb | Electrical | 11 | 07-24-2012 01:15 AM |
| A/C wiring manual says 14 awg & 20 amp breaker? | brianosaur | Electrical | 13 | 06-17-2011 04:57 PM |
| Manual D Friction Rate Worksheet | kilosos2 | HVAC | 38 | 01-11-2011 05:36 PM |
| Manual transfer switch to power an existing sub-panel | joestewart | Electrical | 10 | 11-23-2009 03:30 PM |
| Thermostat from Manual to Digital | trinamillersmit | HVAC | 5 | 07-02-2009 10:21 AM |
