Making My Own Concrete (or Mortar) Edger Pieces - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-25-2007, 10:31 AM   #1
Making my own concrete (or mortar) edger pieces
I stucco'd my house, but bought all my stucco in advance, and now have waaay more bags than I needed (like 40 more 80lbs bags).
I started thinking that I could make edges for all my flower beds/around my driveway, etc. I figured I could make something cool here, and paint to match my stucco.
I want to pour them in place, not make them in a mold and then put in place.
The actual cutting holes/putting wood in for the sides of the edgers seems simple enough, but any tips on how to make an attractive top to the edgers? I know I can't free-hand trowel a finish that would stay uniform, so I was thinking maybe using crown molding or something to form the tops. Any ideas or tips would be highly appreciated!
joeyboy is offline   Reply With Quote
Old 06-25-2007, 11:39 AM   #2
Rewards Points: 324
I just used simple wood and masonite forming and then poured and hand troweled. Took about 1.5 hours from start to finish of pouring/troweling. Forms took WAY too long because I was picky.
tigerbalm2424 is offline   Reply With Quote
Old 06-25-2007, 11:54 AM   #3
Very nice! It looks like your rear wood form was raised higher than the front, is that accurate?
Old 06-25-2007, 11:58 AM   #4
oh, and how deep underground do they go?
Old 06-25-2007, 01:21 PM   #5
Rewards Points: 324
Correct, the back piece was raised higher than the front. I intended to do a "mowers edge" type shape but ended up just rounding off the top slightly. The troweling was very quick and easy. Cost was only about $20 in concrete and used from extra boards/masonite I found laying aorund. I think the depth was about 3 inches underground, way overkill, but thats just how the forms ended up when I was ready to pour!
Old 06-25-2007, 01:28 PM   #6
Well, awesome job man, thanks again for the info!
One last question - how did you keep the forms in place? I imagine you just used a flat board on the front, and one on the back. I was thinking that I'd attach stakes to teh boards, so that I could mallet them into the ground at the perfect height. Did you just put the boards in place or did you affix them somehow?
The pics are great, I'll def post some when I'm done (I'm renovating so much stuff right now on my first house that I don't want to start doing too many pics until I'm done, since everything's kind of 'under construction' simultaneously lol).
Old 06-25-2007, 01:40 PM   #7
Rewards Points: 324
I took a 2X6(because I have millions laying around) and cut it into strips just like stakes(1X1X10"), pounded the stakes into the ground where I wanted the curve to go and then screwed the stakes to the form boards. I did this on ALL the boards I used for forming. All the straight section is done in 2X6 boards and the curve forms were masonite for bending purposes. The only annoying part was getting the two forms spaced evenly between. I did 4.5 inches in between. I didnt put any stress cracks in the concrete while it was drying (because I was lazy) so I have two stress cracks in the concrete. Cant notice them unless your a foot away for closer.
Old 06-25-2007, 04:05 PM   #8
concretemasonry's Avatar
Rewards Points: 2,608
I don't think a pre-packaged stucco mix would be the right product for a curb. Something with small rock would be a little better.
Also cut a few control joints into the edging where it fits the design. The you will control where the cracks will be and they will look more finished. - Especially important if you have frost.
concretemasonry is online now   Reply With Quote
Old 06-25-2007, 04:36 PM   #9
Do you think it would be beneficial for me to buy some medium/coarse aggregate to mix into my stucco? Any particular ratios? I'm only doing this project because I have sooo many (40) bags of stucco leftover, so I wanted to put it to use.
Old 07-18-2007, 12:42 PM   #10
http://www.diychatroom.com/showthrea...ed=1#post53445
Thanks for the pics and info tigerbalm!!! Mine are quasi-done, that thread I linked is the pics. I have a bunch more sections to do (which will be harder as most of them are arches and not straight lines.. arches with corners )
I'll post more pics once I do the arch sections, and once they're really finished (painted, grass in place, landscape beds full with mulch, etc)
Old 07-18-2007, 12:54 PM   #11
Rewards Points: 324
Very nice job!
Old 07-18-2007, 03:43 PM   #12
Thanks man! It only took 2 'practice' runs on smaller areas (which were smashed apart shortly after being made) to get a feel for it. Still really worried about doing the large arch ones, it'll be interesting to see how well those come out. They're large arches, *and* they're on a pretty steep slope. I've got a lot of planning to do before pouring those, I'm thinking thin wood that's flexible or sheet metal. And doing them in small sections, otherwise the slope will kill the shape.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
