Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-05-2010, 01:24 PM   #1
Make them grow straight
I have 2 maple trees currently gowing .. and I want them to grow straight.. (I have 2 other maple grows.. they are not straight and now they are too big).. How can I do that ?
I currently tied them with the rope around the branches.. what is the best way of making them grow straight..
http://i699.photobucket.com/albums/v...h/P7040334.jpg
http://i699.photobucket.com/albums/v...h/P7040335.jpg
cprao is offline   Reply With Quote
Old 07-05-2010, 01:30 PM   #2
DIY'er
jamiedolan's Avatar
What do you mean by making them grow straight? The trees in the photo are grown more as a bush (as it is many small trees together) with many branches from the ground. A tree is normally 1 trunk from the ground.
Jamie
jamiedolan is offline   Reply With Quote
Old 07-05-2010, 01:48 PM   #3
Jamie
Well. I am sure I didn't put my question right. I have 2 other maple trees they did not go straight. I meant, after the trunck the main branch did not go up but bent towards the ground and into my backyard. I want this to go up straight. Does this make any sense to you ?
Old 07-05-2010, 01:51 PM   #4
DIY'er
jamiedolan's Avatar
So are you talking about pruning these tree - bushes out and just leaving one tree, and you want to make sure that tree grows up straight?
Jamie
Old 07-05-2010, 02:02 PM   #5
Jamie
Yes. I wan to make sure the tree grows up straight. As you said, in this case there were many small trees. All these small trees grown from the trunk (There was a tree, I cut it last year since it was fallin on backyard).
I though it was died.. but appearently it didn't.
Old 07-05-2010, 02:39 PM   #6
DIY'er
jamiedolan's Avatar
In this photo, I drew lines were I can see at least 3 different trees growing from the ground. I am sure these are all tied in together below ground at some point.
If you want this to grow like a tree, then you are going to need to remove these extra trees, leaving the best looking one. It doesn't really matter how connected they are now, they are obviously too low to ever be meaningful branches on the tree its self.
Once you trim out the excess trees / branches if the one that is left isn't straight, then you can work on straightening it. You can use something like a dowel or a bamboo steak, and tie it to the part of the tree that needs to be straightened with something flexible like a nylon stocking. Make sure to watch it frequently as it grows, so the stocking or the dowel doesn't grow into the tree, if you just leave it long term, the tree will eventually get girdled and die. You will likely be able to remove the steak by next spring, maybe sooner, all you can do is try it, and check it in a couple months and see if it is straightened out.
Jamie
The Following User Says Thank You to jamiedolan For This Useful Post:
cprao (07-05-2010)
Old 07-05-2010, 02:47 PM   #7
Attachment 22237
Jamie
Thank you for pointing those addttional trees. I am sure there are more than three trees in this bush. So basically you want me to identify the good looking one and cut the remaining trees. Then make sure the good looking one is growing straight (using the above technique).
Am I getting the point ?
Old 07-05-2010, 03:25 PM   #8
Ok. I cut down some of the addittional trees. Temporarily tied the straight looks tree with rope. Eventulay replace this rope with bamboo steak or something like that..
http://i699.photobucket.com/albums/v...h/P7040365.jpg
http://i699.photobucket.com/albums/v...h/P7040366.jpg
http://i699.photobucket.com/albums/v...h/P7040367.jpg
http://i699.photobucket.com/albums/v...h/P7040368.jpg
Old 07-05-2010, 04:11 PM   #9
DIY'er
jamiedolan's Avatar
This is a smaller tree, but it was very bent. It is tied on with velcro straps:
You may have to use something stronger like a piece of metal conduit to tie those up to. You may still need to cut back some more to give you enough room to work, to put in steaks and tie up the trees.
I would try and do that fairly soon, once they get much larger, they will be more difficult to impossible to get straight.
Jamie
Old 07-05-2010, 04:20 PM   #10
Attachment 22241
Jamie
Excellent. Thank you very much for your visual display. very much helps. I will do it soon.
How to get bottom of Inkberry Hollies to grow joshoc Landscaping & Lawn Care 4 09-21-2009 06:34 PM
FREE plans/instructions for easy to make Magic Box! DangerMouse General Discussion 5 07-23-2009 05:14 PM
hardwood flooring installation - How do I make a straight edge? McCool Flooring 8 07-03-2009 01:01 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
Anyone know how to make cafe doors? versatile1 Carpentry 3 08-01-2008 10:39 PM
