Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-17-2011, 09:22 PM   #1
Make a mulching kit or discharge chute?
I have a 46" deck for my JD 318. It doesn't have a discharge chute. I cannot find one nor can I find a mulching kit that is compatible. I know I can get mulching blades for it, but they are almost $30 per blade.
Any ideas on how to fabricate a mulching kit or chute myself?
cibula11 is offline   Reply With Quote
Old 09-18-2011, 08:46 AM   #2
The "mulching kit" consists of the mulching blade and a cover to block the chute from the mower deck to the clipping catcher bag. Since your mower does not have a chute, all you need to do is install the mulching blade.
Note that any mower, with or without a chute or kit, will clog during mulch mowing if the grass has gone long since the previous mowing.
Sometimes going forward at a slow speed will improve the mulching.
(from The-Lawn-Advisor dot com)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-19-2011, 01:00 PM   #3
Does anyone know if or where I can find a discharge chute for this deck? I searched and searched and came across one metal one listed on ebay, but the bidding had ended. I can't believe that another one somewhere doesn't exist. I contacted a parts dealer and they did not have a mulching kit or plate that covers the opening for this model.
Old 09-19-2011, 01:38 PM   #4
A Little Of Everything
Can you find the model number on that deck?
Also, my experience with mulch cutting is that it's a waste of time and effort. It works, but only under absolutely ideal conditions, and when you're only trimming the grass.
DrHicks is offline   Reply With Quote
Old 09-19-2011, 02:07 PM   #5
I don't have the model number with me, but I'll get it. I'm not as concerned with whether it mulches or not as I am with figuring out a way to direct the cut grass.
I will be using it to mow a townhome complex and the last thing I need is a wayward rock. Even a discharge chute would be helpful.
Old 09-19-2011, 02:49 PM   #6
Absolutely! You've gotta have the discharge chute.
Most of the newer John Deere mowers have a rubberized plastic discharge chute. Pretty good stuff, actually. They can take a real beating. I wonder if you could pick up one of those, and somehow mount it on your deck?
Old 09-19-2011, 02:55 PM   #7
Yeah, that's all I need. It doesn't have to look pretty, just function correctly. I'll keep searching. Thanks.
Here's the model number: M00595X
I also found one on ebay that came off a STX 46 with model number
John Deere # M121131
Anyone know if that might work?
Old 09-20-2011, 12:00 PM   #8
So, I finally was able to locate something that would work. One place I can get a plate to cover the deck (but it is not to mulch grass, just leaves) The other place online found a undermount mulch kit for my deck. My options are:
1. I buy the plate cover with mulching blades for around $80
2. I buy the mulch kit for $170.
I didn't know what others had thought about mulch kits or if just having a plate to block to deck opening would suffice?
Old 09-20-2011, 02:26 PM   #9
Completely different machine, so I don't know how relevant this is, but the mulching kit, or recycler kit as I believe they call it, for my Toro, was more than just the chute cover and blades. It also included a long formed piece that wrapped behind each of the three blades, essentially enclosing them, and 6 pyramid shaped pieces, two for each blade housing, which supposedly change the air flow, allowing the blades to lift the clippings more effectively. I don't know how much difference the piece that wraps around the blades and the pyramid shaped pieces make, as I never tried it with just the mulching blades, but I do know that the difference between the basic mower deck, as I originally purchased it, and that same deck, after I installed the recycler kit, is like night and day. I would never have another mower without a mulching deck. We have a lot of trees, so a lot of leaves in the fall, and the only raking we do is to move them out from around the house and barn, to the lawn, so that I can chop them up.
Old 09-20-2011, 03:25 PM   #10
That helps. Now I'm being told by one dealer that they have a part for my 46" deck, but my local dealer says no, its for a 48" deck, so..........
Old 09-20-2011, 03:39 PM   #11
And therein lies one of the main problems with John Deere mowers. They had about a gazillion different models.
Again, if it were my call, I'd go with the discharge chute.
Old 09-20-2011, 03:56 PM   #12
Thanks, I contacted the dealer and he told me he made a mistake. As far as I know it looks like the only options are either buy a plate that covers the opening (with our without gator blades $80) or buy the OEM chute for $105
How to make recessed shelving DesignDuoBlog How To Guides 0 08-30-2011 05:20 PM
Mulching around Trees chenzarino Landscaping & Lawn Care 1 05-03-2010 07:17 PM
Mulching blades on a low end mower cellophane Landscaping & Lawn Care 2 04-20-2010 08:27 PM
two discharge lines on compressor? cmac HVAC 2 05-31-2008 10:16 PM
Do they make this? Malcolm Roofing 3 10-14-2007 12:23 AM
