Major Yard Damage By Skid Loader - Help! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 09:21 PM   #1
major yard damage by skid loader - help!
I had a skid loader remove tons of concrete sidewalk from the front yard. It rained and the clay soil got chewed up severly. After attempting to grade the mud, they left me with a mess. There are holes, ruts, and puddles.
How do I fix this?
kscarguy is offline   Reply With Quote
Old 10-16-2009, 10:01 PM   #2
Too Short? Cut it Again!
You are probably going to have to till it to break up the chunks and overcome the compaction the skid loader caused. Then you will have to regrade it. You will not accomplish much if it is soaking wet though---especially if it is heavy clay.
Old 10-16-2009, 10:10 PM   #3
my plan?
I thought of adding several truck loads of topsoil to fill in the puddle areas and help it drain. Then when (if ) it ever stops raining, I'd rent a big tiller. I'd throw old leaves, some sphagnum Pete moss and course grade sand over the area and then try and cut everything in.
Not sure if this is a good plan.
Old 10-17-2009, 07:24 AM   #4
Adding topsoil might fix the problem cosmetically but you will not be doing the already compacted clay soil any good by putting more on top of it. You may have long term growing problems in the damaged areas if you just fill in the damage. Whatever you do you should be patient and wait out the weather.
Old 10-18-2009, 07:52 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
Ayuh,... Adding to it could also change the elevation, causing drainage issues...
Bondo is online now   Reply With Quote
Old 10-18-2009, 10:48 AM   #6
Don't know it all, yet!
I have NEVER successfully graded mud. If nothing else, just when you almost have it close to where you want it, your tires/tracks will get in a soft spot, the tractor will tilt or slide and then you have made another mess to smooth out. Sorry, but you are going to have to live with it untill it dries out enough to work with. The more you try now, the more you will have it clumped and compacted to where nothing will grow. Sounds like the skid steer operator tried to at least get it to a liveable pile until later. As long as it didn't erode severely or have water standing in a lake-sized puddle, I couldn't fault him just yet. I would think he would have touched base on this with you though.
Just my 2C worth!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-19-2009, 12:32 PM   #7
Rewards Points: 152
I think your plan is spot on in terms of improving the soil for lawn.....but you just gotta wait til it dries out first. Some gypsum might help in the mix to break up clay some more.
piste is offline   Reply With Quote
skid loader vs dump trailer 4just1don Building & Construction 3 07-20-2009 05:14 AM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 04:06 PM
Skid Steer: Buy vs Rent DIY_JC Landscaping & Lawn Care 13 02-19-2009 10:26 AM
How to Fix Termite Damage iammos Building & Construction 12 07-21-2008 04:58 AM
