Maintenance Question On Pea Gravel Deck - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 07:38 PM   #1
Rewards Points: 107
Maintenance question on Pea gravel deck
We have some mildew and moss on couple of small Pea gravel decks.
1. How do you clean them without damaging the decks?
I did researched and it sounds like regular mildew bleach cleanser might
harm the adhesive of deck.
Already, some of little gravel is coming off from the deck as it is getting
old.
2. How do you recoat the surface to strengthen the gravel from coming off?
Is it something DIY or do I need to hire professional?
If I need to hire, is it the deck company or landscape company?
Thanks in advance.
Andee77 is offline   Reply With Quote
Old 08-03-2012, 07:53 PM   #2
Too Short? Cut it Again!
You might check the website or call customer service at Abatron and see what they say about your situation. They have great products and support. You can ask honestly if you can do the project yourself.
www.abatron.com
My concern is that if the material binding the gravel has cracked and moisture has gotten in and encouraged mold growth you should probably call someone who does these sort of decks to remedy that and put on a new binder/coating.
Old 08-03-2012, 07:59 PM   #3
Rewards Points: 13,712
If you have an epoxy coating with Pea Stone imbedded in it your out of luck trying to fix it. Once it starts to fail it's all over and can not be fix.
Always go with exposed agrigate concrete instead.
There's other mildicides avalible that are sold in Lowes and Home Depot. I've seen then in the paint area.
Under deck question/ ideas sm424 Building & Construction 7 07-03-2012 04:39 PM
Unique deck question amcinnis1 General DIY Discussions 5 06-12-2012 09:52 PM
Deck structure question houseinthewoods Building & Construction 5 06-13-2010 09:18 PM
Pergola over Deck Question figgyb44 Building & Construction 2 06-10-2008 07:50 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
