Low Voltage Post Light - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 10:23 AM   #1
Hi All,
I would like to install a standard post light and perhaps some other lighting around my driveway. For the driveway lights I am intending on putting a 12v transformer in my garage and running the low voltage out.
The post light is where I hit my snag. Most all of the post lights I see are line voltage whereas I would like to run it off of my low voltage line. Is this as easy as buying the post light of my choice and tearing the wiring out and adding a new low voltage receptacle? Is there a reason low voltage lights would be poor in this situation?
Thanks,
Brian
b_corwin is offline   Reply With Quote
Old 10-16-2009, 09:20 PM   #2
Too Short? Cut it Again!
I've been known to hit the auto or marine supply store for such retrofits and it works out fine if you can find something bright enough. Watch the power draw on the transformer and beef it up if you have to though. You might see if there is a low voltage LED that is bright enough.
Problem with wiring (really long post sorry) okacookie Electrical 10 04-21-2009 08:54 AM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
How To: Post Nathan Site Help and Suggestions 0 07-04-2008 03:08 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 07:46 AM
