Low Voltage Lights On Vinyl Siding? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 05:21 PM   #1
Low voltage lights on vinyl siding?
Greetings,
Not sure where to address this, but we build a composite deck that sits low on the ground and has no railing. We'd like to add some lighting and are looking at some low voltage lights. We have them all mapped out, but we'd be lacking in lights along the part of the deck that is up against our house.
Is there any reason we can't attach some low voltage lights directly to the vinyl siding of our house? Are there any considerations or precautions we would need to take? Caulking, etc?
Thanks in advance.
LarsD is offline   Reply With Quote
Old 10-04-2013, 06:20 PM   #2
Rewards Points: 13,748
Wall leaks, how would you run the wires, the siding needs to be able to expand and contract.
Just not a great idea.
Old 10-09-2013, 10:49 AM   #3
dmclean701's Avatar
Rewards Points: 152
Those low voltage lights get amazingly hot, especially the 18 watt bulbs. I have had fixtures age from heat. I wouldn't put put the lights directly on the siding.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 10-09-2013, 12:51 PM   #4
Consider adding them to the soffits.
Old 10-09-2013, 02:14 PM   #5
Rewards Points: 774
If it's just a 4w or 7w fixture, the heat won't produce enough to melt the vinyl. I wouldn't want to drill into or screw into the siding for water leaking concerns. It's possible you could use some 3M fasteners/tape, etc. to run the wires. Certainly a halogen bulb would be way to hot and could damage the siding. I guess it just depends. Do you have pictures of the siding/location?
cibula11 is offline   Reply With Quote
Old 10-17-2013, 11:32 AM   #6
Rewards Points: 156
If you think head would be a problem, you may want to go with LED bulbs for the low voltage lighting. They produce hardly any heat, and consume little power.
av-geek is offline   Reply With Quote
Insurance claim for vinyl siding thru-hiker Off Topic 3 12-02-2010 02:29 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 10:28 AM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
