Low Voltage Lighting - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-01-2009, 02:12 PM   #16
Light 'em Up
If that budget is tight start off with a few good Kichler fixtures, as you said, and you can get retrofit LED bulbs later if you decide you want to go that way. Every year LEd are being mde better for less money, so in that respect you may be better off going with halogen for now anyway.
northwestNate is offline   Reply With Quote
Old 05-01-2009, 02:16 PM   #17
Thanks - I think thats the way to go - I need to find a good Kichler supplier and take it from there - you do any remote "design" if a pic of the application is sent to you?
meth is offline   Reply With Quote
Old 05-01-2009, 02:26 PM   #18
If you go with incand. and you don't use all the bulbs in the string the voltage to each will be higher due to poor xformer regulation, so for long bulb life I recommend a series high wattage resistor on the low voltage side of the 'former. Then you can select your lamp life vs. brightness.
Old 05-01-2009, 02:38 PM   #19
Light 'em Up
I can definitely help you with the design and I can give you good prices on Kichler fixtures. Visit my site and contact me with any pictures or more information. My emails on the bottom of the contact page.
Old 05-13-2009, 02:09 PM   #20
Thanks - I am trying to pick out a fixture style to get an idea. I will send you a couple of pics along with some measurements. What is the proper spacing for path lights? My walk is ~60ft I would guess - should I space them at 10' apart?
Old 05-13-2009, 03:53 PM   #21
I guess that depends on the circle of light thrown by each fixture, which depends on the height of each fixture.
Low Voltage Landscape Lighting in difficult areas ronski Landscaping & Lawn Care 1 04-23-2009 04:11 AM
outdoor low voltage lighting DDASH Electrical 2 07-08-2008 09:56 PM
Low Voltage Cabinet Lighting Recommendations BigJimmy Electrical 2 01-20-2008 02:01 PM
Low Voltage Lighting Bulb Life IdahoBob Electrical 2 12-23-2007 01:24 AM
