Low Spot On Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-26-2008, 09:15 AM   #1
Rewards Points: 1,088
Low Spot on Yard
I have a low spot on my yard that's approximately 2.5' in diameter.
Is it a better idea to cut the sod under it, pack in fill dirt, and then throw the sod bad on top, or
break up the sod, put fill dirt on top of that, and then spread new seed?
I'm thinking the former.
handy man88 is offline   Reply With Quote
Old 09-26-2008, 02:48 PM   #2
47_47's Avatar
Rewards Points: 58
If the spot is shallow 1" or less, I'd add soil on top and seed. Deeper than that and if the grass is in good shape, dig up the sod fill your hole and replace the sod.
47_47 is offline   Reply With Quote
Old 09-27-2008, 10:37 AM   #3
Don't know it all, yet!
Handyman
What lawn do you have? Adding topsoil can work on some lawns, i.e. fescue. To do it right for any lawn, cut the sod back, level the soil, then replace the sod. Try to get as many roots as you can.
Water well.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-27-2008, 06:36 PM   #4
Originally Posted by downunder View Post
Handyman
Water well.
Fescue.
Normally, it's not a big deal, but since this spot is on a swale, I want to make sure it's done right.
Old 09-28-2008, 06:19 PM   #5
Your definition of a swale please?
Old 09-28-2008, 07:04 PM   #6
A small valley on the lawn used to channel and route water away from one location to another.
Old 10-01-2008, 06:00 PM   #7
handy man
Maybe it's just me, but I'm not seeing why you want to correct a low place in a swale. Is it so low that it is preventing the water from draining away, mower scalping, etc.? By the way, to repeat what 47 said, how deep is the area? Since it's only a couple feet in diameter, I would just dig the sod out, fill in to level, and replace the sod. Just wondering if you have a situation there that I have not come across before and that I could learn from.
Good luck,
Richard
How do I know if it's safe to grow vegetables in my back yard? dragonness Landscaping & Lawn Care 8 07-24-2008 08:30 AM
My yard is ugly and I don't know an easy way to fix it. keyser soze Landscaping & Lawn Care 22 07-05-2008 02:43 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 01:10 PM
Back yard now leaking "black water" tripower Plumbing 5 08-06-2007 04:56 PM
Remulching my yard is NOT an option, other suggestions? PICS J187 Landscaping & Lawn Care 20 05-27-2007 01:05 AM
