Low Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 03:50 PM   #1
Rewards Points: 774
Low Retaining Wall
I have a small, 20 ft retaining wall that is only 2 blocks high with a cap installed over that. It runs along side of my driveway and hold in river rock.
My question whether I should continue the wall around the whole north part of my house. I have curved the wall around a bush and it ends at my foundation. The problem I have is that I was planning on stopping the wall and then using interlocking edgers to complete my edging because the grade of my driveway really flatens out.
If I use the retaining wall blocks it would only be 1 block high for about 20 ft. I didn't know if that would look right or if people really use wall blocks for that long of a run at only 1 high?
So my options are
1) continue with 1 block high retaining wall at take the caps off my current wall (would be too high for a block and cap)
2) stop the wall (like I have) and continue with edgers
cibula11 is offline   Reply With Quote
Old 07-27-2007, 07:14 PM   #2
So my options are
Post a pic if you can, a lot easier to advise that way. I just finished a similar project myself but used wood instead of block.
Medium_Pimpin' is offline   Reply With Quote
Old 07-27-2007, 07:57 PM   #3
Rewards Points: 774
I actually decided to keep the wall block going. When it got really low and one full block was too high, I used the top cap. Looks nice.
Old 07-29-2007, 12:02 AM   #4
I guess U should go for the long wall with 1 block height.I dont expect it to look horrible.anyway I have seen ppl so that and still the place dint look all that different
HiFi is offline   Reply With Quote
Retaining wall drainage werc Landscaping & Lawn Care 12 05-23-2008 10:43 PM
Retaining Wall riverdees05 Landscaping & Lawn Care 4 09-17-2007 01:16 PM
Retaining Wall Help jb3green Building & Construction 6 07-01-2007 11:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
