Looking For Non-decorative Wall Blocks - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 03:16 PM   #1
Looking for non-decorative wall blocks
I'm wanting to build up a garden that currently drops off from my driveway pad. The wall needs to be about four foot high at highest point. The wall will not be visible, so I don't need a wall product that is decorative....it just needs to be sturdy.
Pinhighdad is offline   Reply With Quote
Old 07-06-2012, 08:48 AM   #2
Too Short? Cut it Again!
Not sure I understand? You need a retaining wall? What is the slope to be like on either side?
Old 07-06-2012, 09:48 AM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Since you need a retaining wall there are two choices:
1. A rigid wall with a concrete footing at the appropriate depth for the frost and a reinforced wall to eliminate cracks.
2. A "flexible" wall that is built on a compacted soil base (about a foot or so below the surface) with a slight "batter" (3/4" per foot or so back into the slope) for stability. This type of wall allows the minor temperature and moisture movement without loss of stability. The wall is usually built using specially shaped concrete block or wood timbers. The are many different styles of block and generally have color or some sort of facial treatment because of the minimal difference in manufacturing cost.
Dick
concretemasonry is offline   Reply With Quote
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Surfacing open decorative blocks lakeresident Building & Construction 4 12-17-2011 04:13 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
