Locating Sprinkler Supply Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 01:45 PM   #1
Locating sprinkler supply line
I dug up the sprinkler valves in the back yard to either move them or cap them off to lay a patio. They were deeper than I anticipated. I looked at the supply side of the valves, and thought I knew what the supply line was, but it heads away from the house I have a complete circle around the valves, but don't want to continue digging if its just for another sprinkler.
dariusld is offline   Reply With Quote
Old 09-14-2012, 03:22 PM   #2
I cut everything out and turned on the front valve and water came out of the pipe circled. Would they run that line all the way from the front yard?
Old 09-15-2012, 11:51 AM   #3
Rewards Points: 3,418
They usually run the supply line to a manifold where the valves are located,and hook up the zones to the valves in the manifold.
Canarywood1 is offline   Reply With Quote
Broken underground supply line Eds_tls Plumbing 2 07-26-2012 07:07 PM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 10:54 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 09:51 AM
add an additional register to a supply line b2v HVAC 1 06-20-2006 07:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
