Lines In Lawn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 06:45 PM   #1
Rewards Points: 160
lines in lawn
how do the pros always get the nice looking lines in the grass? is it because the grass is nice and the mowers they have are good? or do they have something behind the mower that makes the lines too.
jhack836 is offline   Reply With Quote
Old 04-20-2012, 07:02 PM   #2
Learning Things Every Day
Jay 78's Avatar
I guess I'm a pro, because my lines always look good!
Unless you're talking about something else, the lines are just wheel tracks. Drive straight (or at a 45 angle if you're feeling ambitious), and you get nice lines. I use the tracks as a guide, always keeping the wheels of the mower precisely on the track from the previous pass.
I have used different mowers and my grass is in bad shape in the front yard (back yard is nice), so I don't think either of those things are that important. Nice thick grass always helps, though.
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-20-2012, 09:35 PM   #3
Rewards Points: 160
i always use my rider for different patterns, my lines are straight as an arrow. i think its probably the thickness of the grass because my lines arent as noticeable
Old 04-21-2012, 09:21 AM   #4
Rewards Points: 768
The lines are called 'stripes'. It is accomplished by a couple of things happening. It happens when the blades of the grass are pressed down (by weight of the mower, wheels, striping kit, etc.) and also by the way the blades on the mower lift the grass. Zero turn mowers do this best, but even my rider does a decent job, providing you cut your grass no shorter than 3 inches. Google striping kit for mower and you'll find lots of options.
cibula11 is offline   Reply With Quote
Connect Air Cond Drain to House Waste lines AdamOJ Plumbing 19 11-23-2011 07:47 AM
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 01:45 PM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 08:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 11:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
