-   -   In-Line VS. Anti-Siphon Valves? (http://www.diychatroom.com/f16/line-vs-anti-siphon-valves-79513/)
C_J_GO 08-23-2010 09:44 PM
I have a friend that has decided to install a sprinkler system. Since I have installed a couple, I designed one for his yard and was out to buy all the parts for it today. I noticed that Rain Bird is only selling in-line valves in stores around here. I have always installed the above ground anti-siphon valves just due to the fact that if I need to work on them, they are more easily accessible without having to lean down in a hole. So ny question is why did the anti-siphon valves disappear and what makes the in-line valves the way to go?
GardenConcepts 08-29-2010 01:20 PM
Different states have different rules about this. Here in PA, we can use a double check valve (an in-line valve), but in NJ the law calls for a pressure vacuum breaker, which is probably safer. If you use a PVB it should be installed at least 1' higher than the elevation of the highest sprinkler.
