Leveling Yard For Playset - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 09:05 AM   #1
Leveling yard for playset
My yard slopes 9" over 14ft so I am looking to level it for a swing set with tower. I didn't want to dig down the high side as I was afraid I'd hit underground irrigation so I humped in topsoil in & leveled a 12'x14' area using a compactor. I sloped the built up end down to the existing grade below it. My concern is that without any retaining wall/wood the tower will sink or the dirt when wet will give way from the weight on top of it. The compacted soil is pretty hard but it's all top soil no stone dust. Any suggestions? Would it stand? Should I build a wall on the one end? should I remove the dirt and start over Ugh? Would rather get it right now before I build the kit set that will sit on top of the ground i.e. unable to adjust to ground by cutting the set down.
Thanks for your input
Pub352 is offline   Reply With Quote
Old 04-09-2012, 12:03 PM   #2
Rewards Points: 13,446
Concider using pressure treated 6 X 6's as a retaining wall. I cut out notchs so the one piece over laps the other and drill with a 1/2 drill, then pound in 1/2" X 24" long rebar to hold the corners tight.
6 X 6's are below ground rated.
Any real lumber yard will have them 16' long.
Old 04-09-2012, 02:04 PM   #3
Thanks JoeC, That's what I was pondering, So would you do a u shape on the sloped end ? So cut into my dirt after the highest point (by stakes in photo) & place 6x6 PT & cover with say 2-3 inches of dirt as the perimeter? I'll try to up load a picture:
Old 04-09-2012, 03:08 PM   #4
Civil Engineer
Rewards Points: 4,686
Topsoil usually means soil containing organic matter. While this is great for growing things, it is generally considered unsuitable for supporting things, even something as light as the swing set supports. My recommendation is to place compacted crushed stone or gravel under the swingset supports, the rest of the area can be topsoil or whatever fill you want, but the supports should rest on structural fill, of which crushed stone is the lowest cost, easiest to place. If the support is 1 ft x 1 ft, make the stone about 2 ft x 2ft and you should be fine. Excavated down to mineral soil before placing the crushed stone, if you put it in over topsoil the topsoil is going to compress, leading to an out of level swingset.
Old 04-11-2012, 06:37 AM   #5
I hear you Dan, so maybe blocks under the tower corners, down to the "hard soil", as the supports are not posts but the square frame of the tower. (sorry it wouldn't let me upload a picture)
Old 04-11-2012, 10:06 PM   #6
This article was written well ,I like…I will keep your new articles
las vegas pavers
las vegas paving
lasvegaspaving1 is offline   Reply With Quote
Leveling yard profenx Landscaping & Lawn Care 9 02-02-2011 10:05 AM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 10:03 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Yard leveling techniques for playset wallyyoung Landscaping & Lawn Care 10 08-17-2009 05:27 PM
Leveling a yard, please help save my life! bob johnson Landscaping & Lawn Care 1 10-15-2008 05:48 AM
