Leveling Patio Space - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 08:36 AM   #1
Leveling patio space
Hey,
I will try to explain best I can, I am planning to build a patio on a 10' x 14' spot, but it slopes down approx 1.5 ft - 2 ft top to bottom, it was a walkway to with gradual steps but everything was so rotted I had to tear it all out. What's the easiest way to level the ground, out in that area to make it suitable for a stone patio?
I am thinking to use cinder blocks to build a retaining wall on the low end, does that make sense or is there a better way to do this?
jlatour is offline   Reply With Quote
Old 05-30-2011, 09:56 AM   #2
Energy Saver
HomeInsulation's Avatar
Hey jlatour,
Welcome to the site...
You'll definitely need a retaining wall to level out the ground if your planning on a patio. Using concrete blocks to level off the ground may sound easy, but if you want it to last, you'll need to dig a trench and pour concrete to use as a footing or base for the concrete blocks.
It's a little extra work, but without a solid footing concrete block walls sag, bow and crumble in a few years. Leaving your patio unlevel and potentially dangerous if you have small children who will trip and fall.
Another option are solid concrete retaining wall blocks sold at Lowes and The Home Depot. They also require a solid foundation, but it doesn't have to be poured concrete.
If you post some pictures of your project, it will help us all get a better idea of your yard.
HomeInsulation is offline   Reply With Quote
Old 05-30-2011, 11:16 AM   #3
Newbie Bill
Rewards Points: 518
Yes Welcome.
I agree with HomeInsulation and would suggest going to the retaining wall blocks instead of the cinder block. The foundation is critical.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-01-2011, 09:25 AM   #4
Does it matter what kind of retaining wall blocks are used?
mrsql is offline   Reply With Quote
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Concrete space b/w patio & house Drakestar Building & Construction 7 08-26-2010 11:20 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
