Leak In PVC Under Walkway - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-06-2013, 12:59 PM   #16
Too Short? Cut it Again!
That is what I meant to say if I did not. Use the drain pipe for your conduit. If it is a drip circuit you do not need the pressure rating of PVC although you are not talking a huge difference in cost I guess. You probably want PVC on the potential pressure side of the valve though. I would check that that valve is rated for low flow while you are at this?
Might want to note or sketch what you did somewhere for the new homeowner that follows you.
Old 04-06-2013, 01:31 PM   #17
Rewards Points: 20
If you can find it in your area go with Poly pipe. It's easier to use than lengths of PVC.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
user1007 (04-06-2013)
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
