Lawnmower Won't Start... - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 07:43 PM   #1
Lawnmower won't start...
Probably get this around here a lot. My mower wouldn't start at the beginning of summer. I sprayed starter fluid into the carb, and it would turn over then die. I gave up on it after five or so tries. The next day I was going to take it in, but decided to give it a go and it started up on the first try. Worked fine all summer, but then the sun killed our grass. Haven't had to mow for over a month. The autumn rain has brought our grass back, and it needs a trim before the winter months. Well, the same thing is happening. The gas is less than two months old, it has fresh oil in it. Starter fluid is making it turn, but then it dies.
Any ideas? I'm not remotely mechanically inclined, so layman's terms are appreciated. Thanks in advance.
nickh44 is offline   Reply With Quote
Old 10-12-2013, 07:57 PM   #2
Framing Contractor
Rewards Points: 118
Try changing the spark plug.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
nickh44 (10-12-2013)
Old 10-12-2013, 08:29 PM   #3
Rewards Points: 13,712
Time to remove and rebuild the carburetor.
Try to only use nonethanol fuel or at least add an additive to counter act the effects of it.
Never leave gas in it when storing, dump it out and let it run until it stops.
This time of year only buy a gal. at a time.
Anything left over at the end of the season can be dumped into your vehicle.
Old 10-17-2013, 03:51 PM   #4
Rewards Points: 590
I use Sta-Bil in the gas and that works for my lawn tractor, mower, and 4-cycle trimmer. I still clean the push mower's carb with Gumout every spring.
operagost is offline   Reply With Quote
Old 10-18-2013, 11:59 AM   #5
Rewards Points: 91
I wouldn't go pulling the carburetor just yet. Granted, it probably needs to be cleaned and rebuilt, but start simple. The fact that it runs for a little while when you spray starter fluid is pretty indicative that it's a fuel related problem (could be simply a clogged fuel filter), so check that first.
Change the air filter, fuel filter, and spark plug if you haven't done it in a while, and report back.
NegativeTen is offline   Reply With Quote
Old 11-25-2013, 02:55 PM   #6
biggles's Avatar
drop the float bowl and clear the nut in hand(holds the bowl).... orifice with a sewing needle...
my lawnmower will only start crossing wires marcus oshea Landscaping & Lawn Care 4 06-21-2010 07:43 AM
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Murrary Riding Lawnmower Won't Start lerxstrulz Landscaping & Lawn Care 14 05-08-2010 11:27 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
