Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-28-2011, 07:02 PM   #1
Still Learning
Lawnmower not sucking up grass
Um... Is my lawnmower not sucking up the grass because the blade is dull? Or are there more causes for this problem?
thehvacguy is offline   Reply With Quote
Old 03-28-2011, 07:09 PM   #2
the Musigician
DangerMouse's Avatar
ummmm, what kind of mower? If it's supposed to be bagging it, then look for blockage.
If you mean lifting it to cut it, that's different. That would mean the blade is not rotating maybe?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-28-2011, 07:13 PM   #3
Still Learning
Well its a regular push mower that self propels. It cuts the grass but only fills the bag with 3-4 handfulls of grass before it leaves a trail of cut grass on the lawn. I noticed a hole in the bag so i patched it, but the problem persists
Old 03-28-2011, 07:17 PM   #4
the Musigician
Wet grass and/or dull blade then, yup.
Most likely the latter..... it'll rip up clumps of grass and plug the opening.
DM
Old 03-28-2011, 07:35 PM   #5
Still Learning
Ok i have a toro proline tv5004. It never used to have a problem with wet grass. I removed a LOT of dry hardened grass from where the blade is, and i noticed the blade is really smooth. Man, my lawn looks like crap now...
Old 03-28-2011, 07:56 PM   #6
the Musigician
Well, sharpen that puppy up and get to mowin'!
DM
Old 03-28-2011, 08:23 PM   #7
Tileguy
Bud Cline's Avatar
The shape and design of the bottom side of the mower has everything to do with how the machine produces the venturi-like action necessary to both lift and transfer the clippings. If the underside isn't kept clean and free of debris the action is diminished. The shape and condition of the blades is what also produces the actions necessary for the machine to do its thing as designed. Worn or bent blades can be an issue.
Old 03-31-2011, 02:46 AM   #8
DM
Exactly
shauntie is offline   Reply With Quote
"soccer-resistant" grass or 2nd best? ilyaz Landscaping & Lawn Care 3 01-25-2011 07:04 AM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 09:10 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 11:53 AM
Lawn - Grass Seed, Weeds dankreboot Landscaping & Lawn Care 2 05-18-2009 03:28 PM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 09:06 PM
