Lawnmower Has Leak In Gas Tank - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 01:50 AM   #1
Lawnmower has leak in gas tank
I dont know how this happened but I have filled my mower a couple of times and it runs out real fast. I checked again today and the gas tank is completely dry. Do I have to buy a new mower? Ideas?
furchild is offline   Reply With Quote
Old 05-17-2011, 09:11 AM   #2
Rewards Points: 5,336
You need to check out where it's leaking before you make plans on replacing or repairing.
Put the mower up on sawhorses so you can see the underside of the tank. Check out the hoses that go from the tank to the carburator. Did one come loose? Any splits or tears? Check the tank for cracks, especially along the seams. Check for corrosion spots on the tank. If nothing is obvious, have someone slowly add gas to the tank while you look under the tank for leaks with a strong flashlight.
Also check the carb for leaks. There's a float bowl that's split in two. The nut that holds them together can loosen or the gasket between the halves can leak.
If the tank is leaking, there should be stain marks on the floor where you store the machine.
Ron
Old 05-17-2011, 09:11 AM   #3
Rewards Points: 22
So, is the tank actually leaking, or is it the fuel line, filter, or other component? Regardless, if gasoline is actually leaking, you should be able to identify where it is leaking from, and any of the components should be available at your local dealer.
Old 05-17-2011, 10:19 AM   #4
A Little Of Everything
Rewards Points: 1,356
No, you don't have to buy a new mower - unless you really want to.
Find where it's leaking, and repair or replace it. It's that simple.
We can't tell you where it's leaking. We'd all be doing nothing but guessing.
DrHicks is offline   Reply With Quote
Old 05-17-2011, 02:46 PM   #5
Leak in Lawnmower Gas Tank
Thank you all very much, especially Ron for the detailed "how to". When it stops pouring outside I will take it out and try to find the leak.
Old 05-19-2011, 11:19 AM   #6
I have a similar problem. I hate to replace this mower because it has run like a charm for about 8 years now. I bet I haven't pulled the cord 3 times to start it more than twice. BUT! The tank (or something connected to it is leaking).
I can replace hoses (probably) but what if I do find a crack in the tank itself? Can that be repaired? If so, how?
Swampworks is offline   Reply With Quote
Old 05-19-2011, 11:22 AM   #7
It is very common for the cheap little hose/tube from the tank to the carb to get brittle and start leaking. You can buy said hose, at just about any auto parts store, for (at most) a few dollars. And get new clamps.
It is rather rare for a gas tank to start leaking, unless it has been hit with something. Even so, I assume you can buy replacement tanks somewhere. I just don't know where, because I've never replaced a lawn mower gas tank.
Old 05-19-2011, 12:16 PM   #8
You would assess the cost of repairing the tank or replacing the tank versus a new mower.
You would first find the leak.
Ron
Old 05-19-2011, 02:11 PM   #9
Should have been a little more specific I guess.
Can a crack in a tank be repaired? Is there a product that will seal the plastic that is readily available to the average consumer?
Old 05-19-2011, 02:28 PM   #10
Yes, JB Weld will work, can be found at auto parts stores. There are several varieties, pick the one that suits your situation best.
FixitDragon is offline   Reply With Quote
Old 05-19-2011, 02:32 PM   #11
You can weld certain types of plastic, but you would need to speak to the repair guys about a gas tank. I would lean towards a new tank myself.
It's easy enough to do price shopping on the internet. I just ordered some parts for my string trimmer at Sears direct.
Ron
Old 05-19-2011, 05:04 PM   #12
It it's insured you could arrange for an, um, unplanned fire. Check your home owners policy and see if it covers lawn equipment. That's what I would do, I would never ignore a chance to get paid to burn something.
KeithWhisman is offline   Reply With Quote
The Following User Says Thank You to KeithWhisman For This Useful Post:
Ron6519 (05-19-2011)
well pressure tank leak wengang1 Plumbing 16 10-07-2010 09:59 AM
leak in toilet tank and water suply Ramcatt Plumbing 3 09-03-2010 10:16 AM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 03:12 PM
Hot water tank leak Bill46 Plumbing 1 08-20-2008 10:34 PM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 09:11 AM
