Lawnmower Blade Marks In Grass - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 05:39 PM   #1
Rewards Points: 77
Lawnmower blade marks in grass
Just cut the grass today and after i was finished i noticed a lot of circle marks from the lawnmower blade in the grass. It's a Toro walk behind. Anyone know what's up?
asbury park is offline   Reply With Quote
Old 04-21-2012, 05:43 PM   #2
Civil Engineer
Rewards Points: 4,526
Might check if all the wheels are set to the same height.
Daniel Holzman is online now   Reply With Quote
Old 04-21-2012, 06:36 PM   #3
Rewards Points: 77
Checked the mower, wheels are set even.
Old 04-21-2012, 07:05 PM   #4
DIY staff
Rewards Points: 7,174
Bent blade can cause that--
Old 04-21-2012, 09:23 PM   #5
Rewards Points: 150
Check your blade sharpness.....
Jeeps is offline   Reply With Quote
Old 04-21-2012, 09:37 PM   #6
Rewards Points: 77
I'll check the blade to see if it may be bent. Blade was sharpened about 7-8 cuts ago. However the turf in the front has much more sand in it which can dull the blade quickly.
Old 04-22-2012, 10:07 AM   #7
was the grass extremely wet...or long when you cut it? If you are mowing to the "sand"...you may be cutting it a bit low. You want to set your mower to only cut about 1/3 of the blade per mowing.
lowvolter is offline   Reply With Quote
Old 04-22-2012, 11:32 AM   #8
Rewards Points: 77
Some area may have been a little damp and high. I don't cut that low. It's bermuda and i keep it at about 2".
Old 04-22-2012, 12:35 PM   #9
biggles's Avatar
blade is upside down?
Old 04-22-2012, 02:18 PM   #10
Rewards Points: 768
The best bet would be that the wheel height is off somewhere....that or your blade is not leveled, which could be because it is bent or loose.
cibula11 is offline   Reply With Quote
Old 04-23-2012, 07:28 AM   #11
Rewards Points: 1,418
You are walking too fast or the engine is not up to full throttle.
For a given RPM the blade makes only so many swipes per second. Only the outer two inches of the blade does the cutting, and also may not do a good job if the blade is rotating too slowly. If you walk faster than two inches per blade half revolution then there can be uncut grass.
Old 04-23-2012, 12:21 PM   #12
Msradell's Avatar
Rewards Points: 90
Bermuda grass does not cut well with a rotary mower, that's why golf courses don't use them. To cut Bermuda properly you need a reel mower. Something like this: http://www.mclanemower.com/reelmowers.asp or depending on the size of your lawn you could use one like this: http://www2.fiskars.com/Products/Yar...en/Reel-Mowers with the bonus that you get exercise also!
Msradell is offline   Reply With Quote
Old 04-23-2012, 05:50 PM   #13
Too Short? Cut it Again!
Ditto on the reel mower suggestion for Bermuda, bent grass, etc. It is very hard to set a rotary mower low enough to cut such grass without it dishing with every surface imperfection on wheel hits.
Old 04-23-2012, 06:50 PM   #14
Rewards Points: 77
Why would it happen this time and not in the previous cuts on the lawn?
Lawnmower not sucking up grass thehvacguy Landscaping & Lawn Care 7 03-31-2011 02:46 AM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 09:10 PM
AC Electric lawnmower Headfirst Electrical 4 11-29-2009 12:34 PM
