Lawn Tractor Starting Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-22-2009, 11:12 PM   #1
Question
lawn tractor starting issue
i have a murray widebody that is about 10 years old and in good condition, but for the ignition system. i have replaced the battery, selonoid, and ignition switch but still have problems turning over the engine. normally, when the key is turned, nothing happens, no click, buzz, or purr. after many tries, suddenly it turns over and starts normally. all contacts are tight.
any ideas???
lyonheart is offline   Reply With Quote
Old 05-22-2009, 11:38 PM   #2
It's the cranking circuit, not the ignition. There must be an intermittent open or an interlock switch preventing cranking. Can you post a schematic?
Old 05-23-2009, 10:41 AM   #3
Don't know it all, yet!
Some systems have an in-line fuse in the circuit. If you have one, it could be just loose or about to go bad.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 05-23-2009, 12:54 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
check your owners manual and find out where the starter interlock switches are,there are probably a couple[seat-clutch-pto-ect.] check these conections and swithes and make sure the linkages engage them properly
Tom Struble is offline   Reply With Quote
Where to find great quality artificial lawn Kwak Landscaping & Lawn Care 3 10-24-2011 09:32 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 12:36 PM
Help with SHOT lawn nsb318 Landscaping & Lawn Care 4 05-09-2007 11:10 PM
