-   -   lawn tractor starting issue (http://www.diychatroom.com/f16/lawn-tractor-starting-issue-45048/)
lyonheart 05-22-2009 10:12 PM
i have a murray widebody that is about 10 years old and in good condition, but for the ignition system. i have replaced the battery, selonoid, and ignition switch but still have problems turning over the engine. normally, when the key is turned, nothing happens, no click, buzz, or purr. after many tries, suddenly it turns over and starts normally. all contacts are tight.
any ideas???
Yoyizit 05-22-2009 10:38 PM
It's the cranking circuit, not the ignition. There must be an intermittent open or an interlock switch preventing cranking. Can you post a schematic?
downunder 05-23-2009 09:41 AM
Some systems have an in-line fuse in the circuit. If you have one, it could be just loose or about to go bad.
Tom Struble 05-23-2009 11:54 AM
check your owners manual and find out where the starter interlock switches are,there are probably a couple[seat-clutch-pto-ect.] check these conections and swithes and make sure the linkages engage them properly
