Lawn Tractor Battery - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 01:28 PM   #16
Rewards Points: 76
So you have a large, presumably red, cable running from the positive terminal of the batter to the starter solenoid, and from one of those points you have a smaller, again, presumably red, wire running from either the battery or the same lug on the starter that the cable is connected to, to the ignition system. I would disconnect the wire to the ignition system, and check the current draw again. If it is still drawing current, I would suspect the insulation on the positive battery cable or the solenoid, but if the current draw is eliminated, I would suspect something on the ignition or accessory side, starting with the ignition switch.
Old 05-10-2011, 01:51 PM   #17
Pretending to be Retired
5 Amps is a lot of current when everything should be off. I'd do like DexterII said for now.
BigD9 is offline   Reply With Quote
Old 05-10-2011, 10:41 PM   #18
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Thanks guys. I'll give it a try this weekend, or sooner if I get a chance.
WirelessG is offline   Reply With Quote
Lawn Help garydigital Landscaping & Lawn Care 4 03-06-2011 03:36 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
lawn needs help ursula Landscaping & Lawn Care 9 01-31-2010 11:19 AM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
