Lawn Tractor Battery - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 08:05 PM   #1
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I have a run of the mill Toro (MTD) lawn tractor. The battery wouldn't turn the engine over last night, so I put a charger on it until it was full. Without running it today, the battery is again dead. If I buy a new one, this will be 3 batteries in 4 years. It seems that the only batteries available for lawn tractors are cheap $50 products. Are there better ones out there, do they just die like this, or is there something odd at work?
WirelessG is offline   Reply With Quote
Old 04-25-2011, 08:07 PM   #2
Framing Contractor
Rewards Points: 120
My last tractor made it 15 years on 2 batteries. Are you sure your charger is working properly or is on the correct setting? If that checks out, I would buy a different brand of battery at least.
sixeightten is offline   Reply With Quote
Old 04-25-2011, 08:24 PM   #3
A Little Of Everything
Rewards Points: 1,364
For the most part, your off-the-shelf lawn tractor (and motorcycle) batteries are pretty crappy. Consider yourself VERY lucky if you get 2 years out of one.
But not all of them.
When my sons & I were doing our side-line lawn care business, we a John Deere F525, with a John Deere battery in it. The battery lasted (I believe) 6 years. I'm not sure if we were just really lucky, or what.
DrHicks is offline   Reply With Quote
Old 04-25-2011, 08:41 PM   #4
Pretending to be Retired
Do you have a multi-meter where you can check the current draw from the battery when the switch is turned to the off position?http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
If you have a current draw then you need to fix it first before you replace the battery.
Or do you have a hydrometer and is the battery the type where you can check the 6 cells for charge? If you can check the individual cells for charge, and one or more are shot then the battery needs replacing. http://www.ehow.com/how_4964575_use-...ydrometer.html
Either the battery is shot or there is a current draining the batteries.
BigD9 is offline   Reply With Quote
Old 04-25-2011, 08:56 PM   #5
Rewards Points: 120
I pretty much agree with DrHicks on this one, but three batteries in four years is a lot, under any circumstances. So, again, agreeing with DrHicks, I have always bought lawn and garden batteries from an implement dealer or auto parts store, and have not based my puchase decision on price, but on their recommendation for my application, and I have had good results doing so. I have heard others tell of "getting a deal at XXX" (local big box or whatever), but I have also heard the same ones tell the same thing in consecutive years, so, in my opinion, they are not saving a thing. The other thing that you need to look at, particularly on "price competitive" equipment, is the wire size, types of terminals they use, etc. I would suggest that while you have the battery out, look at the ignition switch, light switch, safety interlocks, cable connections, etc. Take the wires loose, examine them, clean the connections, and reinstall them. While they are not necessarily carrying full voltage to the starter, a little bit of excess voltage draw here and some more there can add up to enough to cause the charging system to struggle keeping up, and while it may be enough to appear that everything running fine, over the long haul, or short haul in this case, can mean that your battery is not adequately maintained.
Old 04-25-2011, 09:17 PM   #6
Hey here's a kicker for ya...
I've got a Kawasaki Vulcan motorcycle. Bought it new in April of 2005. This will be my 7th season of riding it on the original battery. No idea how I've managed to pull that off, but this guy ain't complaining!
Old 04-25-2011, 09:20 PM   #7
firehawkmph's Avatar
Rewards Points: 1,902
Wireless,
Get yourself one of these and your batteries will live a lot longer. I normally get 5-6 years out of my batteries whether they're for the boat, atv', lawn tractor, etc.
http://www.chaparral-racing.com/Prod.../321-2100.aspx
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-25-2011, 10:40 PM   #8
WirelessG's Avatar
Rewards Points: 698
Thanks for the input all. I'll look into it when I get back in a couple days. I do have a multimeter and it's a piece of crap, but it might just be able to root out a current drain. Mike - I use a smart charger currently and it does a pretty good job (I assume that is what you meant by your post as opposed to your specific charger).
Old 04-26-2011, 07:47 AM   #9
Our battery was constantly being drained, even after we recharged it. We changed it 3 times, finally we found out it was a faulty Stator.
Good luck.
screwy is offline   Reply With Quote
Old 04-26-2011, 08:20 AM   #10
Current drains are sometimes very hard to find. I just traded my loved 1999 Chrysler Town and Country in because of that very problem. It had a small current being used that would over 4 days draw the battery down so it wouldn't start. I knew it was in the fuel system somewhere (when I removed that fuse the current draw stopped), but nothing I did would fix the problem.
So if the tractor doesn't have any phantom current draws, and all battery connections are good, and starter relay is good, maybe you have just gotten bad batteries. Speaking of starter relays, have you attempted to jump the tractor bypassing the starter relay? It could be bad especially if it has some age on it.
Good Luck and be safe
Old 04-26-2011, 11:13 AM   #11
Something is draining the battery. Lights, ignition switch, hour meter...something. My John Deere did the same thing. Take it to a dealer to have it fixed for sure.
pjordan4477 is offline   Reply With Quote
Old 04-26-2011, 02:49 PM   #12
Too Short? Cut it Again!
What are your winter storage conditions?
Try a battery supply store, not a factory brand name replacement, and explain your situation.
Old 04-26-2011, 04:01 PM   #13
hi, one fellow here in savanna, illinois took a ride to o reillys in freeport,illinois and picked up a tractor battery with the most cold cranking amps and still fit the battery tray under the seat. $45.00 , and has used it 3 years now, no trouble.
frnkhtc47 is offline   Reply With Quote
Old 04-26-2011, 04:09 PM   #14
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I just bought a replacement for my tractor from Autozone, which came with a 3-year free replacement warranty. With the $10 core credit from giving them my old battery, the total cost was like $30.
hyunelan2 is offline   Reply With Quote
Old 05-10-2011, 12:30 PM   #15
WirelessG's Avatar
Rewards Points: 698
Well, it's drawing a 5 amp current when off. I guess I'll just take it to the shop, but I'll probably wait until it needs some other maintenance (hopefully not until fall).
Lawn Help garydigital Landscaping & Lawn Care 4 03-06-2011 03:36 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
lawn needs help ursula Landscaping & Lawn Care 9 01-31-2010 11:19 AM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
