Lawn Striping Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 07:11 PM   #1
Rewards Points: 160
lawn striping question
how do I get my lawn to look like pic 1 or pic 3 and not pic 2. pic 2 I took after a long summer drought so I know the grass isn't the best but this yr it is fuller and greener and it still looking like that. how do I get the lines to be either dark or light and without that stripe in the middle of each pass. do I need a roller or is there more to it? or is it the professionals? but i have neighbors that make their grass look like pic 3 so there has to be something. is it just my deck? I have a scotts 42 in.
lawn striping question-grasslinessinco2.jpg   lawn striping question-img_2056.jpg   lawn striping question-frame2-101904.jpg
jhack836 is offline   Reply With Quote
Old 05-31-2013, 07:35 PM   #2
Rewards Points: 44
It's from cutting in alternating directions, easiest done with a zero turn mower. There is a striping accessory for some mowers which basically pulls the grass blades in the same direction.
Dan
djlandkpl is offline   Reply With Quote
Old 05-31-2013, 07:45 PM   #3
Rewards Points: 160
I do alternating ways but as you can see in pic 2 it looks nothing like the other pics and it has a line in the middle of mine. like something is wrong with the blades..
Old 05-31-2013, 07:49 PM   #4
Rewards Points: 44
It could be related to the height you cut the grass. I think you get a better effect when the grass is longer. If you google lawn striper, you'll find some DIY ideas as well as products you can buy.
Dan
Old 05-31-2013, 09:27 PM   #5
It's grass just cut it.
Tatertot is offline   Reply With Quote
The Following User Says Thank You to Tatertot For This Useful Post:
vsheetz (06-02-2013)
Old 05-31-2013, 09:40 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Just drive in circles and random patterns.....
Old 06-01-2013, 02:11 AM   #7
Too Short? Cut it Again!
A sharp detatching or stripping blade that, as suggested, rakes the blades in one direction to a point is probably what they are using. And are they, or their lawn service, using a reel type rather than a rotary mower? That can provide the look as well just like vacuuming cleaning the thing.
To each their own, but that look in photo three does nothing for me. Just looks like someone is bragging they mow their lawn. So?
The surface of yours looks a bit dry in your photo so if you are getting a "split ends" look on the surface you probably need to check your blade sharpness.
Old 06-01-2013, 06:55 AM   #8
MarginallyQualified
Rewards Points: 2,464
There is a bit more to it but most of it will happen when you spend $300 or $400 on a striping tool that attaches to the back of the mower.
Open this Link
Old 06-01-2013, 07:57 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Some of the commercial grade mowers also create such good vacuum that they do not require a striping kit to leave those lines.
The striping kits ensure that you will get them though.
Remove old lawn first or concrete first? jimleahman Landscaping & Lawn Care 6 04-26-2012 03:56 AM
re-starting care for a neglected lawn jdrunbike Landscaping & Lawn Care 1 03-31-2011 11:42 AM
Well pump question Davidb6 Plumbing 4 05-04-2009 02:41 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 08:38 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
