Lawn Sprinklers Trying To Fire When Off - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 09:07 PM   #1
Lawn sprinklers trying to fire when off
Hi All
When moved into a new house and there is a quirk with the lawn sprinklers. Now and then, one of the zones tries to fire, even when the system is set to off. It will squirt water for a second, stop, usually try again, stop and then it won't do it again until another 20 mins or so. Sometimes, inside the house this creates a audible clanking sound as the pipes sort of jolt. I notice that if I shut the outside sprinkler water supply off, this activity ceases. But if the water supply is on this quick will happen, even if the zone is shut off on the control box. Any ideas to look for?thanks!
sportinwla is offline   Reply With Quote
Old 03-25-2010, 09:45 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is this while other zones are cycling on or off or with absolutely nothing else running?
Old 03-25-2010, 11:06 PM   #3
Rewards Points: 1,418
The control valve for the zone may be worn or defective.
The typical control valve for a lawn sprinkler system is not a faucet that uses a washer pressed solidly against a seat or a turning ball with a channel through it to admit or cut off the water.
Instead there is a rubber disk with a small hole in the middle that is either covered or uncovered when an electric solenoid plunger similar to a door bell striker is activated. The disk then acts as a flap to let water by or close it off. I don't know exactly how it works but the term "vacuum break" seems to be used to describe it. A leak or a defect in the valve may unbalance the pressure or suction causing the disk to let water by and activate the sprinklers with the electricity off and a moment later the running water causes the pressure or suction to regain the level corresponding to water off.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
lawn needs help ursula Landscaping & Lawn Care 9 01-31-2010 12:19 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 12:36 PM
