Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-03-2010, 04:30 PM   #1
Lawn sprinkler system - changing heads - ?
I have a small lot - 3-zone system that uses pop-up heads. A few of the heads appear to be too short - at full extension, they are spraying the side of the grass (which I try to keep at about 3" or so).
Are these easy to replace? Will I have to excavate around the heads to expose, or are extensions available?
SixStrRzr is offline   Reply With Quote
Old 08-16-2010, 09:01 PM   #2
Don't know it all, yet!
They should be on 1/2 inch lines with threaded connectors. You might want to dig around them just for working room but then again you might could unscrew them and replace with longer risers. Yes, there are many lengths available and as simple to replace as a light bulb.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
sprinkler system jcmx1 Gardening Forum 0 07-27-2010 10:36 PM
PVC supply line for sprinkler system Reddhead Plumbing 1 07-04-2010 01:10 PM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 10:54 PM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 10:46 AM
Sprinkler System Nathan Landscaping & Lawn Care 1 02-09-2004 11:12 PM
