Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-12-2012, 10:59 PM   #1
Lawn Sprinkler pump
Hello, I have an old pump I need to replace. I want to buy the same pump since I know it works for my system. The pump is a flotec Thermoplastic Spinkler Pump 1.5 HP that pulls water from the river.
This is a two part questions.
1. For houses that use city water as a source, do they need a pump for the irrigation system? Is so what kind of pump.
2.If yes to number can centrifugal pumps be hooked up to use city water as a source?
thanks
jburchill is offline   Reply With Quote
Old 07-13-2012, 01:10 AM   #2
Lawn Sprinkler pump
1 - no, not typically.
2 - na
Evstarr is offline   Reply With Quote
Old 07-13-2012, 10:47 AM   #3
sdsester's Avatar
Lawn Sprinkler pump
Municipal water supplies typically have enough water pressure and flow rate for residential sprinkler systems.
If you have many acres and large pipe runs you may need a pump to boost pressure or flow. You would have to check with your water company to determine whether this is allowed and what permits you might need. This might be a good time to call a plumber as you will probably need signoffs on the work.
Are you allowed to pull as much water as you want from the river? This seems unusual.
You might want to post your general location to your profile.
sdsester is offline   Reply With Quote
Old 07-13-2012, 12:04 PM   #4
Lawn Sprinkler pump
Thanks for the reply, I wouldn't do the plumbing work myself since the end result would be calling a plumber anyway. haha. I was just doing a little planning for the future right now.
We are planning to sell our house sometime and will move away from the river and I would still like to have a sprinkler system. So I was just getting some info.
I haven't heard anything about not being able to pull water from the river. Everyone along the riverbanks pull from the river. Sometimes the city has water restriction for use of city water. But I keep pulling from the river no matter what. The river gives you the good and the bad. Damn Floods
Old 07-14-2012, 03:58 PM   #5
Lawn Sprinkler pump
Where are you? What river?
Old 07-15-2012, 07:52 PM   #6
Lawn Sprinkler pump
Valley City North Dakota...Sheyenne River.
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 11:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Flotec Sprinkler Pump Doesn't work jburchill Electrical 4 09-07-2011 03:48 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
