Lawn Renovation Questions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 02:38 PM   #1
lawn renovation questions
I am planning to re-sod my backyard but landscaping is not really my expertise. The backyard is a problem because it is very lumpy and consists of very compacted clay soil. Only grass that ever comes in is crab or quack grass. I will be doing about 6000 sq. ft. and am curious what the most efficient means would be to go about this. I'm thinking about renting the largest rear tine tiller I can find or bobcat or other tractor w/tiller, to break up soil/turf and also till in peat moss or something. Then would probably rent a bobcat with planer attachment to grade. Would this be an acceptable way to renovate the lawn? If so, what is the best equipment to use to accomplish this? Should existing grass be killed first?
dhag is offline   Reply With Quote
Old 02-22-2009, 02:50 PM   #2
Remodeling Contractor
rent a skid steer with a harley power rake which is made for breaking up this clay, kicking out rocks and leaving the yard with an ideal condition to sow seed.
Old 02-24-2009, 11:44 AM   #3
Good of you to fix the soil first. No way roots would have been able to grow through that. Clay will pool water on the surface, and rots some kinds of roots.
When I put in a flagstone walkway last summer, and added in some small shrub planting areas, even the sharp shovel had to be jumped on to go into the ground(I welded the neck the reinforce). I mixed a lot of peat, mushroom soil, some composted manure, and some multch(if it's new it will steal nitrogen though)
Local arborists might be able to do a soil sample (at least check/adjust ph).
Stillwerkin is offline   Reply With Quote
Old 02-24-2009, 07:19 PM   #4
Don't know it all, yet!
Bob,
How deep does that power rake cultivate?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 03-05-2009, 12:44 PM   #5
I dig my business
to dhag
Hi dhag. If your soil contains as much clay as it sounds I would consider bringing in some fresh topsoil. If you could get away with raising your landscape 3-4inches, I wouldn't even bother tilling, simply place a nice bed of top soil, roll it with a hand roller, place your sod and water it lots for the first couple of weeks until the sod has taken. A bed of clay will maintain moisture hence keeping your topsoil moist at all times. Even if you till it, it will eventually get hard again. Just a thought.
Earth Mover is offline   Reply With Quote
Old 03-05-2009, 03:01 PM   #6
A power rake uses a roller with many carbide tips that grind the dirt and kick out all the rocks. When the last pass is down it leaves the soil loose with small dimples like on a gold ball that allow the seeds to collect. Normal wind quickly covers the seed with loose soil so no additional work is needed but to plow and seed. For clay soils, I add peat moss and cow manure and grind it all in while the machine mixes at the same time. There is no better tool for new lawns.
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 08:38 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
Condo/Townhome renovation questions Badfish740 General DIY Discussions 3 06-12-2007 10:58 AM
dump questions about lawn mower KUIPORNG Landscaping & Lawn Care 9 02-21-2007 09:47 AM
