Lawn Mower Won't Self Propel - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 12:03 PM   #1
Lawn Mower won't self propel
My lawn mower won't engage the self propel. I took the transmission apart and put it back together. Still have the same problem. I didn't think taking it apart would fix anything, but I gave it a shot.
The mower is a John Deere JS63C 3 speed. Not sure if the issue is with the transmisson or the gears in the back wheels.
Any help would be great.
sweetwaters is offline   Reply With Quote
Old 06-28-2009, 12:34 PM   #2
Kap
Mowing my life away.
How did the belt look? Was it worn? Did it come off the pulley?
How about the cable or the spring to engage the belt? Are they still intact?
Kap is offline   Reply With Quote
Old 06-28-2009, 05:34 PM   #3
From the troubleshooting section-
Traction belt broken.
Traction belt jumped off pulley.
Adjust transmission cable.
Traction cable stretched or broken.
Old 06-28-2009, 06:07 PM   #4
The belt looks good. All of the cables are in tacted. If I pull the cables the arms on the transmission move.
I tried moving the adjuster that engages the transmission just to see if the gears were not touching all the way.
Still nothing. I read something about the back wheels. Do you think the gears in the wheels might be the issue?
Old 06-28-2009, 07:07 PM   #5
With the engine not moving and the self-propel engaged you should not be able to spin the back wheels. Can you post an exploded view of this machine?
Old 06-29-2009, 08:54 PM   #6
I was able to solve my problem. My neighbors friend works for John Deere and he came and fixed my mower. The issue was with the self propel lever. He adjusted the bracket and that fixed the issue. The lever engaged the transmission. All is good.
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 02:22 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 03:37 PM
