Lawn Mower Stops After Two Seconds.. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 02:00 PM   #1
Lawn mower stops after two seconds..
I have a Weedeater 300 series lawn mower and I haven't had a problem with it all last summer. It worked fine a few weeks ago, but it won't stay on. There is plenty of gas, but it stops a few seconds after I pull the cord. Any help would be appreciated.
Bravid is offline   Reply With Quote
Old 08-02-2008, 02:19 PM   #2
Check the oil. It may have a low oil shutoff.
jerryh3 is offline   Reply With Quote
Old 08-02-2008, 03:49 PM   #3
Contractor - Renovations
fungku's Avatar
Make sure you're turning off the choke
fungku is offline   Reply With Quote
Old 08-03-2008, 05:28 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
sounds as if the float is sticking. find the float bowl at the bottom of the carb, there will be a drain screw on the bowl. shut the fuel off, then unscrew the drain screw wait till the fuel stops coming out and tap the side of the bowl with your screw driver a few times and put every thing back. BOB
Old 08-03-2008, 10:24 AM   #5
Whatamess
If it is flooding it will be putting off black smoke. Try running it with the choke on. If it runs you have a fuel delivery problem.
With this sorry gas we get today always add a fuel stabilizer or empty the tank and run it dry before storage. Carbs gum up very easy.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-07-2008, 08:21 AM   #6
I have similar problem also with mine ...
I also think it is fuel delivery problem... of some sort... in my case... I kind of depends on my luck... sometimes it works for a longer while... sometimes it doesn't.... when it doesn't.... what I do is I open the fuel cap.... start the engine... it ran... then I close the cap... as looks like natural pressure of air forcing the fuel into the engine easier... then it will run ..... and this method works for me so far.....
One day if this method stop working.... I will have to do open up the engine like above said which I really don't have a clue.....
KUIPORNG is offline   Reply With Quote
Old 08-07-2008, 08:37 AM   #7
change spark plug, drain old fuel, clean filter, add stabilizer to new fuel and you should be golden.
pF45 is offline   Reply With Quote
Old 06-20-2009, 01:30 PM   #8
briggs and stratton 300 running problem
Our Weed-eater 20" mower stopped running after only a few mows. It would fire off fine but would only run a second or so. We tried everything short of taking things apart, and were about to take it back to Wal-Mart. I researched online and saw this problem with the B&S 300 everywhere.
We took the advice of removing the cap until the engine was started and IT WORKED! Yay!
So this is some sort of engineering flaw where there is not enough air flow to start the engine. Works fine to replace the cap after all is going. Main thing is to get the lawn mowed.
sewnsew is offline   Reply With Quote
Old 06-24-2009, 10:53 PM   #9
I know this may sound strange but check the gas cap. I had a similar problem with a tractor. It turned out the cap was sealed to tightly and formed a vaccume in the tank after running a while.
rick32 is offline   Reply With Quote
lawn mower problems jamesw6777 Tools 9 08-04-2008 01:22 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 12:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 02:37 PM
