Lawn Mower Problem. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 06:49 AM   #1
Rewards Points: 274
Lawn Mower Problem.
I have a four year old 7 hp push mower. Two things happened yesterday....I was putting it away for the winter, and (1) washed it carefully, and (2) when I was removing the blade, it acidently fell over on its back like a turtle. Now when I try to start it to let the gas burn off before storage, it seems to fire half way through the pull and the pull cord is ripped out of my hand. After many attempts, and having the skin ripped of my finger, it finally started but misses like crazy, runs for a while, and dies. Then is it back to having the cord ripped from my hand and try again.
I was careful with the wash, so I don't believe I got water into the gas, but I drained it anyway, and put in fresh. Also, after it went turtle on me, I let it sit for over an hour to let the oil go back into the reservoir. No carb adjustments were made, I have washed several times each year, and other than pulling a turtle, I don't know what the problem is. Any assistance would be appreciated. Thanks.
polarzak is offline   Reply With Quote
Old 11-02-2010, 10:32 AM   #2
Rewards Points: 156
How did you change the blade? It sounds like the ignition timing is off.
moondawg is offline   Reply With Quote
Old 11-02-2010, 12:18 PM   #3
Rewards Points: 274
Yes, now that you mention it, it does seem like the timing is off, but for the life of me, I cannot see how I could have changed the timing by taking the blade off. I just removed the screw holding the blade on like I have done at least twice a season on several lawnmowers I have owned, for the past 25 years.
How does one check the timing on lawnmowers?
I used to do that in my younger years on cars, and still have my old timing light. Probably different for a lawnmower.
Thanks for your help.
Old 11-02-2010, 12:22 PM   #4
47_47's Avatar
Rewards Points: 44
Did you put the blade back on?
47_47 is offline   Reply With Quote
Old 11-02-2010, 12:23 PM   #5
Rewards Points: 274
No, not yet. But that might be my problem. Found this in a web search.
"A compliance engine (light flywheel and engine brake) will run without a blade, but is very hard to start and will not idle properly".
In previous years I probably ran the mowers dry and THEN took off the blade. This year I took the blade off first.
I will try it with the blade when I get home. Thanks so much.
Old 11-02-2010, 12:29 PM   #6
Rewards Points: 56
Then there you go. They don't run well without the blade.
Old 11-02-2010, 01:03 PM   #7
Rewards Points: 156
YOu know, I almost asked, and then didn't. Good call.
Old 11-02-2010, 02:24 PM   #8
Rewards Points: 274
Well, that was the problem. I feel like a bit of an idiot after having rebuilt a couple of auto engines, and doing all of my car/house maintenance over the years.
Learn something new every day.
Thanks all.
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 05:42 PM
Toro 20332 Recycler lawn mower pcarlson Landscaping & Lawn Care 6 08-10-2011 06:20 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 03:37 PM
