Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-09-2008, 09:37 AM   #1
Cool
Lattice on a slope
I just finished my deck and would like to put lattice under the deck to hide the substructure, but my yard slopes slightly. What would be the best way to install the lattice to conform to the slope?
mschmid is offline   Reply With Quote
Old 06-09-2008, 12:03 PM   #2
Building codes guy, Mod
thekctermite's Avatar
Lattice on a slope
It would look best if you install the lattice panels square to the deck's framing. You can cut the contour of the slope into the panel before attaching it.
It is easy to do...
Clamp the panel in place about a foot or two higher than it will be in its finished location, level to the deck. If you don't have clamps you can use a couple nails or screws in an inconspicous place. Use a scrap piece of lumber as a guide to scribe the grade's contour onto the lattice. The bottom of the scrap will follow the grade, and the top is where you'll hold the pencil to mark the lattice. You'll need to plan ahead with how high you mount the lattice (or how long the scrap is) to minimize waste. Even if you don't cut enough off the bottom to fit, you can always make a straight cut across the top to remove a little more and get the fit perfect. I'd suggest leaving a couple inches at the bottom so the lattice isn't on the wet ground all the time.
thekctermite is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip, we'll be cutting out our top. If we take a look at our cutting diagram, our top pieces are going to be coming out of the top corners. Now you might remember that one of our tops is the... Read More »
Ok now I've rounded off the top of all these fingers and next I'm going to set these up. I'm going to go ahead and use my finger jig on the table saw and just set these a, two pieces of wood so that they're flush with each other like that and clamp them... Read More »
Hi I'm Karen for Expert Village now we are going to make the lattice top for our pie. First we need to slice about 12 strips of our pie crust we are going to first even off the edge we just going to put that to the side. Make those strips about 3 quarter... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be making our shelves. Using the remainder of my birch plywood and then some additional scrap material I'm first going to rip my boards down to 9 inches. Next I'm going to cross cut... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be making our permanent shelf. First off we need to choose a piece of lumber now these are some scrap pieces that I have left from my sheet of plywood. So I just need to pick on that... Read More »
How do you paint PVC pipe or lattice? AndrewC Painting 4 05-10-2008 06:00 PM
Slope for Bathroom Rough in m4larson Plumbing 3 01-27-2008 10:38 AM
drain slope ouchmythumb Plumbing 2 05-12-2007 06:12 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
