Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-02-2010, 05:19 PM   #1
Large, dying spots in grass, Bugs?
I have two spots in my yard about 5-10 sq/ft each that look like they are dieing. at first I thought lack of water but the spots get good coverage. Then I took a close look and it looks like they are aphid sized black bugs stuck all over the blades. Black dots/bugs either way what could this be?
Jasnall is offline   Reply With Quote
Old 06-02-2010, 06:00 PM   #2
Don't know it all, yet!
Sounds like may be chinch bugs.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 06-02-2010, 07:17 PM   #3
I've never dealt with lawn bugs, can I just pick something up for it at the hardware store?
Did some googleing, Sure sounds like cinch bugs is what I have. Found some good info here http://www.pestproducts.com/chinchbugs.htm
Old 06-03-2010, 08:41 AM   #4
Anyone know if Sevin dust would work? Cheap eperiment: Old sock with some Sevin dust, shake it over the area to dust the grass.
P.S. Not sure if this would have any effect on pets should they get in it.
Old 06-03-2010, 05:34 PM   #5
I would go with a liquid.
Old 06-04-2010, 04:48 PM   #6
Just go to your local Home Depot they should have something for chinch bugs. and dont overwater cuz this will help them grow. If the grass is dead you probably will need to replace thats patch or just reseed (will take a bit longer tho) but treat the lawn first before it spreads.
alanmor is offline   Reply With Quote
Old 06-04-2010, 05:41 PM   #7
In my area we use 'nematodes' to kill off these pests.
If skunks are digging holes in your lawn, its a sure sign that cinch bugs are your problem.
I sprayed all my lawns with nematodes last year with good results and have just bought some more, as a backup.
These are living organisms and do not pollute the environment.
Old 06-04-2010, 06:59 PM   #8
Are you sre the dead spots are not from dog pee?
Jim F is offline   Reply With Quote
Old 06-05-2010, 02:47 PM   #9
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 11:53 AM
Those annoying dark green grass spots from dog pee jweiner Landscaping & Lawn Care 2 05-24-2009 10:51 AM
backfill & grass over a gravel trench ??? linboomer Landscaping & Lawn Care 4 05-09-2009 07:54 AM
Large areas of grass dying Shpigford Landscaping & Lawn Care 6 07-05-2008 04:24 PM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 09:06 PM
