Landscape Ties - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-23-2014, 12:27 PM   #1
Landscape ties
I am laying landscape ties around my "parking lot" Should I put some gravel under for water drainage?
BrianN is offline   Reply With Quote
Old 08-23-2014, 12:34 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably going to need slightly more information than that. Your location would also be helpful if you haven't already offered it.
XXX
Old 08-23-2014, 01:44 PM   #3
Rewards Points: 12,868
Read the tag right on the ties, Not below grade rated.
You would be far better off with at least 4 X 4 or 6's. There below grade direct ground contact rated.
By coincidence I just got home from helping someone remove dozens of termite eaten landscape timbers.
Ever notice you can only buy 8' long ties.
That's because there the left over cores from logs used to make plywood.
The center of the log is the softest part of the log.
With 4 X 4's and 6's you can buy up to 16' long.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Fix'n it (08-26-2014), r0ckstarr (08-27-2014)
Old 08-26-2014, 07:22 PM   #4
We live in Central BC. The ground it is going on is sandy. I am figuring that I will dig a 2" trench, fill with drain rock and put the ties onto that. That way there will at least be a bit of drainage under the ties.
Old 08-26-2014, 08:22 PM   #5
Just going to rot out.
Please reread my post.
Old 08-26-2014, 09:30 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Let's clear up some terms!
Are you using "landscape ties" or "landscape timbers"?
Landscape "ties" are railroad tie stock used in landscaping, they are about six inches buy nine inches and come about nine feet long. They are usually treated with creosote and weigh about ninety pounds each.
Landscape "timbers" are typically in the range of 3-1/2" with two rounded faces and come 8' long and may weigh 10 pounds each. They are usually treated with a petroleum product or CCA (green) treated.
So...which is it?
XXX
Old 08-26-2014, 10:21 PM   #7
So...which is it?
They would be landscape timbers.
Old 08-26-2014, 10:38 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay, back to Post #3.
XXX
Raising Rafter Ties builditbig Building & Construction 2 03-04-2014 01:48 AM
Collar ties or rafter ties? jvetter713 Building & Construction 4 03-31-2012 10:36 AM
setting aluminum railing posts in 6"x6" pressure treated landscape ties. remdel4lesbyric Building & Construction 1 05-19-2011 06:51 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 10:56 PM
