Originally Posted by zamobafood
I attempted to add a 35W spotlight to my exiting landscape ligthing. I also replaced the 105W transformer with a 200W. The load before the spotlight was around 70 to 75W. After the spotlight was installed every other ligth in the system dimed. Current wiring is 16 gauge about 175-200 ft long. Will a larger gauge solve the diming problem or should I wire the system diffrenlty?
Check your voltage at the end of the line. You might want to do both, heavier wire and wire differently, 200' is a pretty long run
