-   -   Landscape Lighting (http://www.diychatroom.com/f16/landscape-lighting-78856/)
zamobafood 08-15-2010 08:58 PM
Landscape Lighting
I attempted to add a 35W spotlight to my exiting landscape ligthing. I also replaced the 105W transformer with a 200W. The load before the spotlight was around 70 to 75W. After the spotlight was installed every other ligth in the system dimed. Current wiring is 16 gauge about 175-200 ft long. Will a larger gauge solve the diming problem or should I wire the system diffrenlty?
Mr Chips 08-15-2010 11:44 PM
Check your voltage at the end of the line. You might want to do both, heavier wire and wire differently, 200' is a pretty long run
zamobafood 08-16-2010 06:17 PM
Will do. I've heard of using a T method or loop in wiring. What benefits do those types provide?
Utah Lighting 03-31-2011 03:56 PM
Check Voltage
The human eye cannot tell the difference when landscape lighting is running between 10.7 and 12 volts. The Utah outdoor lighting systems we install follow this rule and it has helped give us a range to work in.
