Landscape Lighting - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 08:50 AM   #1
Landscape Lighting
I am trying to install a low voltage system. I already have an older 200 watt transformer. It has 4 terminals (2 Load, 2 COM), and a High/Lo switch. I can't find any manual or instructions on how to connect this, because all the new transformers only have three terminals. How do I connect my wire to this? Do I need to use all 4 terminals? What is the High/Lo switch for? Am I supposed to run one wire from two of the terminals, and come back and connect the other end of the wire to the other terminals?
Kevin321 is offline   Reply With Quote
Old 05-09-2010, 03:17 PM   #2
GardenConcepts's Avatar
Rewards Points: 150
Try out one fixture before doing a permanent installation. You'll connect one of the wires to the load and one to the common. The Hi-Lo switch is probably a switch to go from 12 volts to +/- 14 volts- not a big deal. Make sure the transformer has a built in circuit breaker or fuses and that the transformer gets plugged into a GFI outlet. Keep the total wattage about 10% below the transformer rating.
GardenConcepts is offline   Reply With Quote
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
DIY low-voltage landscape lighting?? kooshball Electrical 1 03-23-2010 05:36 PM
Landscape Lighting la15ota Landscaping & Lawn Care 14 07-08-2009 05:47 PM
Help me pick out landscape lighting vanamc Landscaping & Lawn Care 3 05-04-2009 08:49 PM
Another question about landscape lighting kimberland30 Landscaping & Lawn Care 4 05-01-2009 07:44 AM
