Landscape Lighting - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 12:52 PM   #1
diy'er
la15ota's Avatar
Landscape Lighting
I see that lots of us are working on our patios.
Are any of you also planning to add some exterior low voltage lighting?
We're putting the finishing touches on our pergola and then moving on to installing our paver patio.
http://la15ota.smugmug.com/photos/326054750_FQaRD-S.jpg
Now we're thinking of adding little lighting on it and in the yard, so that we can extend its use into the evening.
My idea is to put a light in each of the posts, pointing down and into the patio area.
There will be a seated retaining wall running along the fence and I was thinking of adding a few lights in there, too.
Anyone have any experiences or suggestions.
la15ota is offline   Reply With Quote
Old 07-17-2008, 06:15 AM   #2
solar powered lighting
The best I could come up with is these: http://www.gigabiz.co.uk/solar_wind_...reet_lamp.html
I wonder if you can get these things on a scale suitable for gardens - they would be fantastic!
cbosleeds is offline   Reply With Quote
Old 07-17-2008, 11:43 AM   #3
diy'er
la15ota's Avatar
Thanks but that's not what I was looking for.
Old 07-17-2008, 12:12 PM   #4
If the low voltage set comes with 10 bulbs and you don't use all 10, the bulbs that you do use will be subjected to a higher-than-normal voltage due the transformer being poorly regulated.
E.g., it may put out 12v at full load and 15v at no load.
Incandescent lamp life is very sensitive to applied voltage, brightness less so.
To fix, you can use a low ohm value hi wattage resistor in series with the string of paralleled bulbs.
10' of #30 wire wrap wire doubles as a one ohm resistor and an 8 amp fuse, and you can adjust the length for the desired voltage. Being fragile and solid [not stranded] this wire needs to be wound around something. I think its insulation is good to 100v.
In any case, there is no electrocution danger below ~48v.
Old 07-22-2008, 12:06 AM   #5
diy'er
la15ota's Avatar
Complete Pergola
Well...this past weekend we finished the pergola. I've added pics to the Project Showcase page.
Old 07-23-2008, 01:38 PM   #6
diy'er
la15ota's Avatar
These are the type of lights i plan to use to light up my retaining wall.
http://www.integral-lighting.com/
http://www.vistapro.com/Product.aspx...tID=1&typeID=5
I'm still undecided on lighting the pergola.
Old 07-01-2009, 05:56 PM   #7
Ever thought of using solar paver or accent lighting?
www.solarcynergy.com makes some nice, although quite pricey landscape light.
LEDpavers is offline   Reply With Quote
Old 07-01-2009, 07:56 PM   #8
1w of LED light for 12 hours is 12 w-h so the solar cells would need to pick up ~20 w-h during 4 hrs of daylight.
The solar panels for each bulb would need to be 1/2 sq. ft., and bigger if you want the night lights to work after several cloudy days.
Old 07-01-2009, 08:13 PM   #9
I definitely agree, but I think you'd be surprised by their technological efficiency. By now means are those units meant to light up a pathway, but not a bad choice for adding color without a messy install.
the fixtures still charge during cloudy days and should reach full charge after about 4-5 hours of sunlight.
Old 07-03-2009, 08:18 PM   #10
biggles's Avatar
check these guys out for lighting options http://www.backyardamerica.com/lighting.htm
Old 07-03-2009, 09:01 PM   #11
I think after a year the person has already decided
Or are you just trying to advertise your site?
Old 07-03-2009, 09:07 PM   #12
You don't miss much!
Old 07-05-2009, 05:53 PM   #13
haha can't get anything by you guys
however, i'm more trying to educate than simply self promote lol.
happy 4th weekend everyone!
Old 07-05-2009, 09:09 PM   #14
LED education - they are still expensive & a lot of them do not last as promised
Class over
Old 07-08-2009, 05:47 PM   #15
TooledUp
What about fake retaining wall lighting?? I dont know how else to explain it, but we have fake pavers in our wall that are actually lights. They look the same as the other parts of the wall, but there is an access panel for the bulb. They are pretty slick and you cant even tell they are there!!
TooledUp is offline   Reply With Quote
Homemade Landscape Lighting Randell Tarin Landscaping & Lawn Care 18 02-28-2012 12:31 PM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
