Landscape edging
I have a quick question. A buddy of mine is making a small landscape bed. Instead of using a product like metal edging, he's using a single course of manufactured block. What's the best way to lay these so that they don't move around like when they are bumped with a lawn mower?
Thanks! David |
A product like pro-edge works well...
I did a forum search and google search. I didn't find anything on the forums, and there are a ton of different products from varying companys called pro-edge. Do you know where I can fine this?
Thanks, David |
Take a look at this and see if it will fit into the scheme. Look at the paver edging instead of the landscape edging.
http://www.snapedgeusa.com/ or http://www.edgepro.com/ |
It depends on what you mean by "block."
If you mean brick, just dig a trench and pour a small footing (4" x 4") - it would help to add some rebar down to a depth of a foot or so every couple of feet - deeper if freezing is a factor. A word of warning, though - the top of the footing will be level. Is the ground level? |
| All times are GMT -4. The time now is 10:52 AM. |
