Kawasaki FE-350 11.5hp 4 Stroke Engine - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 08:17 PM   #1
Exclamation
Kawasaki FE-350 11.5hp 4 stroke engine
OK looking for someone with small engine experience. I have a Horizontal shaft, single cylinder 11.5 hp Kawasaki fe-350 engine 4-stroke. It is on a home built hovercraft. I have run this for almost 4 years with no issue what so ever. All of a sudden when I started runing it performance got worse, and smoke out of exhaust, to a point were I had to play with the throttle just to keep it running, similar to a choke engadged then it died... when I was on ground I checked oil and started spilling out, long story short, gas in oil. And every sense engine has not started.
This seems to have a regular spark ignition, coil mounted above flywheel with a manetic pickup.
Any Ideas?
What I have tried:
Checked for spark, from wire to ground I have blueish spark. Replaced plug.
Took carb off and apart seemed to be clean nothing plugged or dirty that I could tell.
Checked float OK
It has an overhead valve, so I removed the head and looked at valves everything seemed ok other then a quite a bit of black sout on the head. I cleaned head to remove majority of sout. I also checked the piston head and cylinder wall everything seemed fine no scratches. Reasembled and valves seemed to ok and moved with little effert.
compression seams fine, although I have not put a compression tester on it.
I seem to be getting gas, I have also tried starting fluid, not evan a burp of fire seems like.
When I turn it over by pull cord I can hear the compression through carb and exhaust. When I check plug seems dry no build up or anything, does smell like gas.
As a side note and a little history or question, when I trailor this the engine has a Propellor attached to it and had a tendency to rotate sometimes, with spark off, when driving on the expressway, does this have ill effect on the engine, a buddy of mine has said no but I don't trust him sometimes. I have sence started to tie down prop just because...
Any help with this would be greatly appreciated.
wings3630 is offline   Reply With Quote
Old 08-04-2008, 08:31 PM   #2
What color smoke from exhaust?
Old 08-05-2008, 07:08 AM   #3
Whatamess
Go here these guys will help you. http://perr.com/
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Small engine repair tripower Tools 2 07-09-2009 04:28 AM
first engine buy fauer Automotive Repairs 3 01-16-2008 10:04 AM
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 12:34 PM
Small engine problem rkhpapa General DIY Discussions 1 12-09-2006 09:00 PM
Do You Like Koeler Or Kawasaki Engines???? hohandy Landscaping & Lawn Care 1 01-06-2006 03:06 PM
