Joint Fill For Irregular Flagstone Walkway? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 07:51 PM   #1
Rewards Points: 77
Joint fill for irregular flagstone walkway?
I'm in the process of redoing our flagstone walkway in front of our house. The previous owners did a horrible job installing it.......uneven stones, poor joints, poor arrangement, etc. Anyway, i've dug most of it up and am re-laying it. My question is.......the joints are fairly wide, 2-3" in some spots.....so, what would be the best fill for that joint width? I don't want to mortar it and i think they are too wide for polymeric sand. Thoughts?
asbury park is offline   Reply With Quote
Old 05-16-2012, 08:17 PM   #2
DIY staff
Rewards Points: 7,174
Lime stone screenings--very fine limestone powder and sand sized chips---available al most stone yards and quarries--stays put--doesn't wash away as easily as sand.
Old 05-16-2012, 08:23 PM   #3
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
There is a fine groundcover plant called sagina or pearlwort that is great for filling in gaps in stone walks. It grows in a very low carpet, won't interfere with mowing or compete with other plants (but it will help keep weeds at bay):
There are different varieties but this is a common one:
http://en.wikipedia.org/wiki/Sagina_subulata
Probably won't find it in a box store but a good nursery should be able to point you to some sources for seed.
Thunder Chicken is offline   Reply With Quote
Old 05-17-2012, 08:43 AM   #4
Rewards Points: 77
I don't want to go with any ground cover. The walkway separates the lawn from a planting bed. Cover in there would look bad.
Old 05-17-2012, 08:56 AM   #5
DIY staff
I think he was suggesting a moss like plant the would simply add a bit of green to the joints--
Old 05-17-2012, 10:32 AM   #6
Creeping tyme in between flagstones looks nice and natural. The plant doesn't mind being stepped on and it gives off a pleasant scent
creeper is offline   Reply With Quote
Old 05-17-2012, 11:31 AM   #7
Rewards Points: 844
Yeah, the sagina fills in somewhat like the thyme above, but is even finer leafed.
Old 05-17-2012, 09:13 PM   #8
DIY staff
That looks nice--kind of an English cottage look.
Old 05-21-2012, 08:45 PM   #9
Rewards Points: 77
This is the walkway prior to being redone. Joints will be of a similar spacing.
Old 05-21-2012, 09:31 PM   #10
Rewards Points: 264
If you narrow the path you could have smaller joints, don't know if that would work for you 'tho.
Another option is to purchase a few extra stones.
7echo is offline   Reply With Quote
Old 05-22-2012, 11:16 PM   #11
Concrete & Masonry
Rewards Points: 530
This is exactly what I was going to suggest..........
If you decide later that you want to bind it all together with an herb like Thyme, it should grow well in the limestone sreenings as well. I've been told that yogurt helps speed the growing process as well........
jomama45 is offline   Reply With Quote
Old 06-05-2012, 06:32 PM   #12
Rewards Points: 77
Well, here's the finished product. I went with a polymeric sand made for wide joints. It bonded quickly and is set pretty good.
Old 06-05-2012, 07:28 PM   #13
DIY staff
That looks good--big improvement!
Old 06-06-2012, 11:34 AM   #14
DIY-er
Looks good, let us know it it holds up, I haven't had any luck with it over a 1" seal. For looks, you could throw down some peastone gravel between the stones to level it. One word of caution is that it does require mainenance from time to time as some peastone will get dislodged. If you don't mind sweeping the peastone back into the cracks every now and then, it looks fantastic.
KevinPh is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
